20 Most Recent Samsung S7220 Cell Phone Questions & Answers
I forgot my phone lock
For all:
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
samsung-mobiles2.jpg *#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
1/4/2019 1:30:24 AM • Samsung S7220... • Answered on Jan 04, 2019
0answers
My china samsng s7220 network problem plese hlp
manufacturing error
10/22/2013 9:09:57 AM • Samsung S7220... • Answered on Oct 22, 2013
Phone lock code
If your Samsung S7220 mobile phone is locked to particular network,you can get network unlock code from Simpleunlocking.com at reasonable price.Here they ask you to specify the country name,current network provider and IMEI number of your mobile phone.After specifying these details,they deliver an unlock code through email.Then you can unlock it using code by following the instructions given for your mobile phone from that site itself.
7/1/2013 12:06:15 PM • Samsung S7220... • Answered on Jul 01, 2013
Samsung s7220 want to connect with my pc
First you have to do is to install samsung usb drivers
11/18/2011 12:32:25 PM • Samsung S7220... • Answered on Nov 18, 2011
2answers
I put a lock code
U HAVE TO TALK WITH UR MOBILE OPERATOR,HE WILL UNLOCK IT. DO VOTE IF PROBLEM RESOLVED.
11/12/2011 7:17:11 PM • Samsung S7220... • Answered on Nov 12, 2011
I have samsung S7220 with
try online
6/27/2011 12:29:33 PM • Samsung S7220... • Answered on Jun 27, 2011
The fonts in my text
Hi!
You try resetting the mobile phone handset, this will change the font back to its original size.
Hope you found this helpful.
Thanks
Zishan
3/1/2011 4:29:23 PM • Samsung S7220... • Answered on Mar 01, 2011
Samsung e 1160 iforget 00000000 code
try resettin the eeprom you need to enter this code #*7337#
1/31/2011 3:49:17 PM • Samsung S7220... • Answered on Jan 31, 2011
What is the default password for phone lock??
You may contact your network provider Samsung S7220 Unlock Code. I suggest you to visit Samsung Unlock Code site, they will provide you an accurate code fast with easy to follow instructions on how to unlock your phone. Once your phone is unlocked, it will work with any network worldwide and don't have to stick to one network.
Hope this is helpful.
Thanks.
1/28/2011 9:11:04 AM • Samsung S7220... • Answered on Jan 28, 2011
2answers
I need an instruction mamual
I advice you check the link below to search for the user manual of your unit,
manualsonline.com
Type the above link on your web browser to search for the manual of your unit. The link contain virtually almost all manuals of all device.
Take care.
7/6/2010 1:58:57 PM • Samsung S7220... • Answered on Jul 06, 2010
0answers
0answers
3answers
How to resolve constant boot loop in samsung galaxy fame
use usb connection from your phone and your computer to upgrade your phone's operation system from the samsung website
4/25/2024 1:47:43 AM • Samsung Cell... • Answered 9 hours ago
How to hard reset Samsung st1000 camera
To hard reset your Samsung ST1000 camera, follow these steps: Reset Settings via Camera Menu: Open the camera app. Tap on the Settings icon (usually represented by a gear). Scroll down and select Reset settings. Confirm the reset by choosing Yes when prompted. Physical Reset (if needed): Locate the reset button on your camera (refer to the camera's manual for its exact location). Press and hold the button for at least 10 seconds until the camera restarts
4/23/2024 7:17:14 PM • Samsung Cell... • Answered Yesterday
Samsung S9 turning Samsung Music app on by itself
This seems to be a known issue where the Samsung Music app starts randomly1. Here are a few steps you can try to resolve this issue: Check if an app you downloaded is causing the problem: Start the phone in Safe Mode. If the problem does not occur in this mode, then you need to find out what app this is and uninstall it. Wipe the cache partition of the phone from the recovery mode: This can often resolve issues with apps misbehaving. Perform a factory reset: Please remember to backup your phone data before doing this. Once the reset is complete, do not install any apps in your phone yet. Try to check first if the issue still occurs. Check Power Saving Mode: The power saving mode could interfere and block your music-streaming app if turned on. If none of these steps work, it might be a good idea to contact Samsung's customer service for further assistance.
4/18/2024 3:10:20 PM • Samsung Cell... • Answered on Apr 18, 2024
Samsung S7220 Cell Phone Logo
26 questions posted
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
forgot phone lock
  • Cell Phones
