20 Most Recent
HTC Ozone XV6175 Cell Phone Questions & Answers
Why cannot boot my htc xv6175 verizone
- While inserting the battery press and hold volume down + green send key + red end key.
- Press Volume Up to restore manufacturer default.
- Press Volume Down to restore custom configuration.
- Press other keys to cancel.
- Press the down volume button to restart
Free unlock code
There are no free unlock codes available for HTC Ozone phones. But,You can get the unlock code for small price from
MobileUnlockSolutions.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code.
How do you use a flashdrive to bypass forgotten keypad password htc ozone
Maybe the hardware got wrong. Better u try to reset the software by restore factory setting. def password : 123455: picture download phone to computer:I don't know anything about a disk, but I got my pic off my phone with a usb cable and my computer recognized it. I run with Media xp. Now on my older PC I just sent the pic to my t-mobile account and them sent them to my photo ablum. It's a drawn out process and take more time then the cd, but like I said I never got a disk with my phone neither. I hope this helpedREINSTALL SOFTWARE:Dear customer, Try to use the code *#7370# to do a master reset on ur N70, this usuauly works. Or else try formating the phone , press (send + * + 3) keys at same time then press power key until power on and keep pressing the three keys for 40sec.If the above given solutions dont have the desired effect then you have to search for cracked phoinex software and flash your phone with USB cableif still the same then it is hardware problem ( either faulty OMAP or faulty RAM
Htcunlock
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Cdma network is not accessable
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
I am not able to
Hi Did u get the solution for the above.. even i am not able to get the setting... please revert..
Cant receive messages from HTC
You may downloaded such big file to your phone memory, causing your phone telling this info. I Suggest to re-route your download file to memory card. Also you move some additional programs / files from phone to memory card to make your phone has a better performance .
Regards
