20 Most Recent
HTC Magic G2 Cell Phone Questions & Answers
How to unlock my phone screen
vol. down and then power at the same time. youll know what to do when the screen pops up. vol. to pick and power to select. should do ya right
How to fix a htc g2 phone that wont reset
When it comes to the HTC phone as with any ANDROID PHONE it has bugs the same as a computer. Try talking battery out and leave it out for about an hour, or in your owners manual it should show you how to factory reset without the phone completely booted up. If that does not work, you will need to find a corp store for your carrier, they can put them on a machine to reset them, you may lose all your saved info but it willl save your phone. HOPE THIS HELPS
Screen dont lite up on g2 phone
If the fault occured all of a sudden or with a fall then it can be failure of the display unit. To reset the phone , remove battery and keep aside for few minutes and then reset. If the fault stays but the call come comes through and if calls can be made, the fault must be the display .
While charging htc magic, the
Sometimes the phone shuts down when hit with current. All You need to do is to turn to the back of t he phone, remove the battery, leave it for about five (5) minutes, then You fix in the battery back and turn it on. It will power on.
But if it does not power on, then You need to check the battery out in another phone, to see if it will power it on, if it does, then it means the battery is okay, then You further check the phone by testing another battery in the phone, if it turns on then the phone is perfectly okay.
If it does not turn on, then it means there is a hardware problem that need to be checked by HTC help center.
Hope this helped You.
Thank You for using FixYa
Goodluck
I bought an unlocked g2
Hello
You do not need to get a new sim card,all you need to do is to try and unlock the phone because it has been locked to a particular network and needs to be unlocked before you can use it with any other network.
There are many ways to unlock your phone but unlock by code is the simple and safe way.you can get your unlock code online.
THANK YOU FOR VISITING FIXYA
My g2 htc phone won't
It sounds like you have a defective battery. Try a different battery to see if that works before replacing the phone.
CODE?PUK
FOR
G2?
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
Need an unlock code for a T-mobile (UK) HTC G2
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
I need the software to convert video songs and
Here is the download link for HTC video converter software
http://files.redkawa.net/installers/videoconverterapp/503/videora-magic-503-setup.exe
Download and installed it.
Enjoy!!!
Rate this solution.
