20 Most Recent Proton MS-42 LCD TV Questions & Answers
The LVDS cable is loose at the T_CON side. Simple fix. Take the back of of your set. It is the cable on the top middle that has a whole bunch of little twisted wires. With the set off take out the connector and the plug it back in tight. Turn on set and you should be back to normal.
Proton MS-42 LCD... | Answered on Jan 16, 2012
Yes, push the menu button on the remote and scroll through the menu items until you find the color adjustments. Joe
Proton MS-42 LCD... | Answered on Mar 10, 2010
What is wrong with it.
Proton Televison... | Answered on Aug 02, 2018
The TCON board or the LCD panel is faulty. You have to change the tcon board to confirm the fault
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Proton Televison... | Answered on Nov 24, 2016
No. There no seperate fuse for backlighting.
Proton Televison... | Answered on Jul 06, 2016
Normally all the backlight inverters have fuse. It would be an SMd type.
Of you wish to get some more details check the link below
Back-light inverter board will have a fuse. Refer its circuit diagram to locate it. If it should blow up, there will be sufficient reason. Some short circuited components/s. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Proton Televison... | Answered on Oct 14, 2015
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Proton Televison... | Answered on Apr 28, 2015
This is simple: set in the closed caption menu (some cable boxes also have it) called TEXT. Look in the menu and turn it off first in the set and also in the box used if used for signal.
Odd feature and never really took off--designed so some channels like PBS etc could broadcast text.
Proton Televison... | Answered on Apr 03, 2012
Please let me know the model no. of your unit. Also, does the symptoms is the same to all inputs?
Jdvillanueva
Proton Televison... | Answered on Sep 14, 2011
Proton MS-42 LCD TV Logo
6 questions posted
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proton Televison & Video
Most Popular Question
4 year old hdtv picture no longer coming
  • Televison & Video
