20 Most Recent
LG 42PG60 42 in. HD-Ready Plasma TV Questions & Answers
Hello i have a lg 42pg6010 plasma tv and it will
Change the power supply board. Do a google, ebay or shopjimmy.com search with your model number for price and availibility. Be sure to match the numbers from your board to theirs. Take the back off the set and trace the power supply via the AC plug up wires.
I have an LG
Did you try the buttons on the tv? See if it works and let me know. I am starting to think it needs a firmware update though
Ive just got home to
Try a different outlet.
If that still isnt the case then it could be the power supply went on it..
THE FOCUS IS WRONG. i
Plasma screens don't have a focus as such so I suspect a problem with the upscaling of your pictures.
Try a different resolution value or screen aspect size.
Hope that helps.
Does not power up or
Take the back off and check for a couple of bulged caps that might need to be replace in the power supply. You can and also check and see if the VA and Vs voltages are correct coming out of the power supply. There will be a label on the inside panel telling you what the VS and VA voltages should read. repair, or replace power supply.
I have a symbol appeared top left on my LG plasma
Do you have sound ok? As this symbol indicates the audio is muted. If pressing the mute button on the remote control should get rid of it. If not then call your LG dealer to have an engineer call out to perform a total factory re-set & update the software if needed.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
