20 Most Recent
Vizio SV470M LCD TV Questions & Answers
I have a Vizio tv that the logo light is flashing.
SYMPTOM: Blinking VIZIO logo, no power on. Usually after a utility "brown-out.
SOLUTION:
1) Unplug TV power cord. Wait 5 secs and replug.
2) Press and hold TV Power Button for 30 sec.
3) After approximately 1 minute, the VIZIO logo should stop flashing.
4) Press Power Button - TV should power on.
This procedure resets the OS program execution (power spike corrupted the sequence).
Valley Electronics, Stockton, Ca (ret)
What part to replace
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Light won't come on power is plugged in
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
How do I get color adjusted on my Vizio SV470M?
Sure something is wrong, but no technician could tell you where the error is. In a chip, or on the board, or in a cable. Just contact a service centre and ask what they will charge for a diagnose and what it will cost to repair the TV.
My vizio Model SV470M will not turn on the power indicator light is not on either.
First, are you capable to open and repair this?
Being a power issue, we work "out to in". Plugged in wall and Power is not out in the neighborhood are too obvious to ask. Sooo... next .. Once back cover is off, look for and test the fuse on the PSU (power board), also look at this PSU board and see if any caps (capacitors) are bulged or popped. Both of these will kill a board, and usually caused by cheap caps or power surges from the power grid. You can replace the fuse easy enough, but you need good soldering skills to do the caps, and a supplier for the new caps. REPLACE ALL CAPS, not just the obvious bad ones. Otherwise, replace the whole board. Since you mentioned a "No Power" issue, this should fix it. Transformers are not too easy to test, (trans may be "browned" IE: burnt) and chips.. forget it, for both, replace the board. Hope this helps
When I turn my Vizio on it doesn't come on ,no
If power indicator does not lit solid/ blink when tv plugged in that indicates problem with power supply board that got defective and not providing output volts, replacement of power board will solve tv problem
Let me know tv model number written on label at rear of tv to answer your additional question, if any.
Thanks.
