20 Most Recent Vizio VO370M LCD TV Questions & Answers
Lines on my vizio flatscreen
next, replace t-con and videoboard
8/1/2017 12:53:26 PM • Vizio VO370M LCD... • Answered on Aug 01, 2017
Screen has reversed colors (appears to look like a color negative). Everything seems to work ok. Repairable?
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
4/5/2017 11:08:35 AM • Vizio VO370M LCD... • Answered on Apr 05, 2017
When I turn on the power, the orange turns white, but no sound and no video
hello dear , this problem is due to a high voltage fault from the electricity . I have read your message , before you go with your TV to the tech support just loose the TV from behind and check if all cables inside the main board are connected in there positions , second step try to loose the main board and clean it well with alcohol liquid then wait till it dries well .after that , reconnect all cables in there positions and try to turn it on , if it gives you the same fault , that means you should replace a new main board
4/5/2017 11:05:44 AM • Vizio VO370M LCD... • Answered on Apr 05, 2017
Vizio vo370m will power on then turns off log turns red then yellow why
sounds like the power board needs to be replaced. stand by the TV when you turn it on and listen real close near the top where the vents are at to see if it hums. also look in the vents to make sure the backlighting works. if not start with the power board. one other trick is to turn off the TV and unplug it. hold the power button in for 30 seconds or more the plug it back in and turn it on. If that does not work replace the power board
6/19/2014 2:53:43 PM • Vizio VO370M LCD... • Answered on Jun 19, 2014
0answers
Be the first to answer 4/20/2014 3:52:30 AM • Vizio VO370M LCD... • Posted on Apr 20, 2014Be the first to answer
Vizio Universal Remotes
One thing I learned about universal remotes . They do not support all models. Vizio was a walmart brand (correct me if I am wrong) that was just a tv made by sony under a diffrent name. try the sony codes.I had a weird tv plasma the name escapes me but it was clearly not a common name and no remote would work with it even in the search mode. one day we where playing with a viewsat (one of thous free to air remotes) and we where able to successfully scan and make work the tv with it. we tried all types of remotes! in fact at one point we bought a logitech (expensive ) you literly are controled by that company you have to have a account and a internet connection and they want all this personal info just so you can program Your (although would argue like micro$oft that you just had a licence to use meaning you didn\'t own) just to use the tv it was junk $170 back then. So think Viewsat , or some sort of free2air box remote. for Legal satellite viewing (yes you can actually get 100 of free channels legally with a bigger dish like history, and more free) the remotes have extra features like universal remote and since some of these companies have a tarnished reputation for being dirty they seem to have more support then a average universal remote.
3/23/2014 8:50:41 PM • Vizio VO370M LCD... • Answered on Mar 23, 2014
I'm trying to remove the back panel from my Vizio
Make sure you remove the washer/nut for the coax connector. Also make sure you remove all the screws for the video input terminals.
10/30/2013 6:55:01 AM • Vizio VO370M LCD... • Answered on Oct 30, 2013
0answers
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
2/14/2013 6:29:32 AM • Vizio VO370M LCD... • Answered on Feb 14, 2013
I need a vizio vo370M schematic diagram
has anyone found a place to buy a t2d diode 94 or t2d 94 diode for a vizio vo370m power supply board, placment d106
1/25/2013 6:10:15 AM • Vizio VO370M LCD... • Answered on Jan 25, 2013
Vizio VO370M LCD TV Logo
79 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VO Vizio
  • VO Vizio
Most Popular Question
grey lines both sides screen
  • Televison & Video
