20 Most Recent
LG 47LF11 LCD TV Questions & Answers
I have a 47 lg
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Hdmi has no signal on direct tv
i had this type of problem before on a samsung tv it was the capacitors. check all cable(ribbon connectors) first also keep an eye out for bulging caps (at top)
Lg47lf65 tv only 18 months old has stopped working
Yes,u know basic electronic's?U have a soldering iron,and solders.Take the board aparts,take out that capcacitor find out what the micro ferit is and the voltage of the capacitor.Just replaced it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main board for the replacement..
My audio does not match the video on my LG
You can try unpluging it for about fifteen minutes or so, to see if that corrected. If you can try hooking up a DVD player and see if you get the same problm If you do, then it is inside the main board, not a cheap fix, sorry.
