20 Most Recent
Sony Walkman NWZ-W202 MP3 Player Questions & Answers
I cannot use my sony walkman nwz-w202 after formating
You MUST re-create the original folder structure (& files) that were in the unit when you bought it. You will not be able to use it until you do.
The easiest way (I've found) is to find a working unit and copy the structure (& files) from the working unit to the non-working unit.
I have lost my cd of sony walkman NW-E003F
To download the CD's contents go to:
Which operating system are you using
select your Windows OS from the pull-down menu.
Note: only Windows 98 to Windows 2000 (and all OS's in between them) are available for selection. If you're using Windows Vista, 7, or 8 you will have to download one of the available versions and use the Compatibility feature of your OS.
How to fix barbie girl on computer
"fix" implies it's broken.
To replace the broken version:
1. Connect your walkman to your computer. (if you're connected to the Internet, drivers should be installed automatically).
2. Open a window to view the mp3 files stored in your walkman.
3. Find the broken file, delete it and replace it with a working version.
If you meant "fix" as in "edit":
steps 1 & 2 are the same
3. Edit the file using audio editing software (such as AVS Audio Editor), then re-save the file.
