20 Most Recent
Itech i.Tech i.Oval 303 Bluetooth Headset Questions & Answers
What is the pairing code?
The pairing code is a sort of a password that only the primary sender will have on their devise and this code in turn reflects unto the secondary receiver. Failure to insert this code within few seconds the devise will fail pairing and you have to start over again, switching bT on and off again.
Dear sir, i want to
Hi Surendrakait,
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
- Switch off your bluetooth device and switch off your cell phone,
- Switch on your cell phone and then open bluetooth and make sure it's active and is not in hidden mode.
- Now make sure that the bluetooth is fully charged and then switch it on.
- Search for devices from your cell phone , use the pair option in bluetooth connectivity , and add a new pair or create a new pair.
- Then the phone will search for the bluetooth and will detect it , and since this is the first time it will ask you for a pass code , you need to enter default 0000 and then select ok and then the bluetooth device will be paired and hence now you can use bluetooth.
Hope this helps ...:) In case you have any queries , feel free to contact me.
I dont know the passcode to my blutooth
It's usually 0000
Hope this helps; also keep in mind that your feedback is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
I dont know the passcode to my blutooth device
It's usually 0000Hope this helps; also keep in mind that your feedback is important and
testimonial comment about this answer.Thank you for using FixYa, have a nice day.
Why can't they connect to the other phone mob?
You directed this question at me, but unfortunately this isn't my expertise and I am unable to
provide you with a real solution at this time.
Hopefully one of other experts will be able to
provide you with a real solution.
Thank you for using FixYa.
Como activo el bluetooth i.tech
Activa el S5230 en "buscar" y solamente manten encendido el Bluetooh, una vez que lo encuentre, activa la sincronizacion con el pass 0000 (si te lo pregunta.Suerte.
How to reset a bluetooth
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Unable to pair with nokia 2730 classic
After switching on the headset activate the blue tooth on the Nokia and search for the devices in the vicinity. If there is no finding then check if the phone detects another device, a phone or PC . If so the headset must be checked to be faulty with another PC or phone to confirm.
How to us a bluetooth headset to pone
Link it to your cell phone. Cell phones can be easy, but nothing is easier than keeping it in your pocket when you talk. Use a Bluetooth headset to have a hands free conversation. They are typically worn over the ear, and can be used without charging for one to four hours.
Use a Bluetooth headset with your PC. You will probably need an adapter to link up your headset with your PC, and they are placed in a vacant USB port in your computer. It enables your PC to communicate with and through the headset.
Pair your Bluetooth headset with your PC in order to use it for VoIP applications. You must set your headset to the discovery option and allow your computer to roam and link with the headset.
Keep it charged. In order to get the most life out of your headset, keep it charged when you aren't using it. This will ensure that it is ready whenever you need it. Use the standard house charger at home, and buy a car charger for traveling.
Adjust the volume. Make it easy on your ears by lowering the volume to a level that is comfortable. When you choose a setting that is too loud you can hurt the ear drum and if you set it too low you may strain to hear the other person.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
