20 Most Recent
Polaroid a540 Digital Camera Questions & Answers
It won't show anything
it won't turn on checked bat they r fine...hold button down an light comes on saying busy?
My polaroid camera wont turn
Please check the battery first if it has energy by using multitester connecting its positive and negative to test whether there are energies inside and if none pls try to charge if it can charge try to use other batter for isolation if using the new battery then it still the same something wrong with your power supply.
I added a 2gh memeroy card and don't know if it
Yes format your memory card for sure I'm also sending a diagram of an SD card showing the little switch on the side. This switch locks the card from formatting to protect or save images.
Also the formatting of the memory card allows the camera and memory card to communicate properly between the two. Formatting should be done after each time you download pictures to the computer Formatting should be done in the camera the memory card is being used in not the computer.
Here is the diagram.
I have a polaroid a540
That info is backwards. If the picture is too large and all you want to do is print a 4x6, it should be perfect.
How do I turn the
See the buttons at the backside of your camera. You'll see a button with arrow (lightening with arrow) mark at the right side of "OK" button. That's flash button !! Push the button and you can turn on (or turn off) your flash light.
Hope this help and be kind to rate this answer.
(^_^)
How can I get windows 7 to reconize my a540
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
