20 Most Recent
Sony Cyber-shot DSC-W180 Digital Camera Questions & Answers
I wants to recover my
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.Download asoftech photo recovery software
http://www.asoftech.com/apr/Install and open the photo recovery software, select the memory card, and click 'Start' button
Free software download
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as the free Picasa (
http://picasa.google.com ).
How to get back deleted images from dsc-w180
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos.
This blog article reviews and outlines several of the better ones.
The camera lens will not retract and the screen
This
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Sony service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera.
Please take a moment to rate the free answer I have provided for you.
Flash won't work
some cameras will have a auto flash were it thinks the lighting is to bright so turn it to manual
Lost the CD, how do I install in a new computer?
You don't need to install the camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
How to reset sony w180
Remove the battery for 15 mins, replace the battery and go to the Menu and set the Date and Time.
I need to replace the lens of w-180.what is I
I'm guessing that you're experiencing an "access error" (on Sony's) or a "lens error" (on Canon's and others). Unfortunately the replacement part runs about $30 on ebay (
here's one example, just search there for: sony w180 lens), and runs close to the value of your camera (going rate for a used w180 is about $40). If you purchased such a lens, there's no guarantee that you'd be able to fix your camera, as it really is not easy to access the lens.You might want to instead consider that fix techniques have been developed for lens/access errors that do not involve opening up the camera.
See this link. Give these fixes repeated tries. But if unsuccessful, consider purchasing one of those used w180's, or better yet, a brand new model camera.
How do i retrieve deleted
It's very easy, but you'll need to purchase an inexpensive USB memory stick card reader, if you don't own one already. Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos.
This article reviews and outlines several of the better ones:
Turn the power off and
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
