20 Most Recent
Pinnacle Dazzle DVC-100 DVD Recorder Questions & Answers
Horizontal white lines on tv?
i would try it on another television and if that dosnt work then it is probably the module it self, it mght be time to buy a new one
Will not add recording time step four
The reason the box is greyed out is there is not enough room on your hard drive to do it. I record all my movies on a portable USB drive. That way I can take them with me.
My capture card dvc100 will show up in the capture
when you are trying to record and you get this messagescroll to bottom of screen (task bar) right click select task manager applications you will see whats running if you see something you dont need running select end now also under processes see what is ticking over youmight have a virus and users you will see who is using your computerhope this helps
My dazzle 100 is making images upside down
Hi Anako ,Unfortunately , i have no experience with Dazzle and can't be of much help this time .Try deleting / reinstalling the driver . Make sure the driver is compatible with your OS ( operating System ) .Best regards ,Fanaudi .
My friend gave me his
Go to this website and follow the instructions there, that will generate you a new number to use.
Hey Guys,
Thanks for taking the
The problem I have with this same device was all related to the driver. It was not compatible with the Vista Operating system. They have a patch and updated driver and software set that for some reason has not been included in the newer releases. You have to download it from them directly. I know the XBox share a lot of Microsoft code and I assume the PS3 does as well at some point. This may be the same problem you are having. The 500-USB does not share this problem, I picked that up as an upgrade which was the Pinnacle recommendation to solve the issue.
