20 Most Recent HP ProLiant DL380 G6 Server Questions & Answers
RAID 10 Configurarion
www.hp.com/support
8/18/2014 6:07:15 PM • HP ProLiant... • Answered on Aug 18, 2014
Proliant dl380 g6 troubleshooting when
Internal Optical drive is having problem, use external dvd writer
10/25/2013 1:55:34 PM • HP ProLiant... • Answered on Oct 25, 2013
0answers
RAID 1+0 configured on HP DL 380 G6 with two SCSI disks, if one disk gets faulty and new disk inserted how much time will it take to sync/rebuild with the booted diks?
It depends upon the amount of data that is stored on the good hard disk. The greater amount of data the longer the time it will take..The computer will still operate but it will be slower than usual until then data has finished synchronizing to the new hard disk.
1/10/2013 3:29:54 AM • HP ProLiant... • Answered on Jan 10, 2013
0answers
Hard yellow led and allarms
Try reading the error displayed on the front led panel.
12/24/2012 4:17:41 PM • HP ProLiant... • Answered on Dec 24, 2012
Dl380 g6 server not boot after power cut
Check the back for a bad power supply. You should be using dual power with dual supply. It should have indicator light on somewhere. Connect to another source if no LED is on.
10/22/2012 9:16:46 AM • HP ProLiant... • Answered on Oct 22, 2012
Configure static ip on a HP 380 G6
Here is an awesome image tutorial on how to do it http://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
10/18/2012 8:26:41 PM • HP ProLiant... • Answered on Oct 18, 2012
Configure static ip on HP dl380g6
Windows? - Start > Control Panel > Network Connections. Right click LAN Adapter. Highlight Internet Protocol (TCP/IP) > Properties. All three fields must be correctly entered. You will require a Static IP, the subnet mask, and gateway. A DNS server address is only required to resolve the name of the server on a network.
10/16/2012 8:07:25 PM • HP ProLiant... • Answered on Oct 16, 2012
Hp dl380 g6 server shutdown unexpectedly
Check event viewer for Window. Insight Manager (if installed) for HP related problems. Type server name or IP on browser. examples: 192.168.2.1:2301. Localhost:2301. 127.0.0.1 again local.
8/28/2012 1:51:45 PM • HP ProLiant... • Answered on Aug 28, 2012
I can't boot my hp prolinat server 380g6
Hello,I would recommend resetting the jumper switch and the BIOS then retry your install. Good LuckC2Solutions
11/19/2011 5:03:37 AM • HP ProLiant... • Answered on Nov 19, 2011
0answers
How can i boot my hp dl380 g6 server in safe mode
Different system use different F keys to get to safe mode, If F8 is not it, try F10.
Good Luck
C2Solutions
3/5/2011 12:38:42 AM • HP ProLiant... • Answered on Mar 05, 2011
How do I fix window 10 to listen audio mp3 cd
NO PC told at all and posted to Proliant server forum that is no PC and as such the OS is not allowed there w10 nor does it have sound chips, at all, its a server running in huge dark, no humans server farm..... so let me guess you posted to wrong forum and never told PC model sure. so windows sounds work in the test in control panel yes ! the, MP3 is complex, it can be from high data rate, source and will not play unless converted . one thing to try is use this free app called Audacity https://www.audacityteam.org/ then play it or convert it or buy a USB sound dac that can decode any sound file on earth or learn to test you PC first windows sounds work then in google type simple MP3 sound test https://file-examples.com/index.php/sample-audio-files/sample-mp3-download/ works good above so your MP3 is no good or wrong bit rate. if fails yours only , buy new DAC USB dongle now it plays them all if windows sounds are dead the sound driver is missing or on a server there is no sound chips oops. buy the DAC dongle. if only 1 MP3 fails out of 100's find a better one or buy a DAC.
4/14/2022 2:22:04 PM • HP ProLiant... • Answered on Apr 14, 2022
I want to install win2003 r2 on HP proliant ml350 g3. But didn't found usb port. Please someone advice me! thx.
Have you connected a CD drive to the machine via one of the SATA ports?
9/15/2015 3:54:40 AM • HP ProLiant... • Answered on Sep 15, 2015
Not display error light and not display on monitor
When you turn it on, does the fan come on? How about the hard drive? There is a serries of tests called POST. I amc4rying to find out what starts up and see where the problem is.
7/8/2015 6:01:30 AM • HP ProLiant... • Answered on Jul 08, 2015
Reset bios putty
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways. BE SPECIFIC.
6/13/2015 10:00:54 PM • HP ProLiant... • Answered on Jun 13, 2015
HP ProLiant DL380 G6  Server Logo
Popular Tags
23 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProLiant HP
  • ProLiant HP
Most Popular Question
raid 10 configurarion
  • Computers & Internet
