20 Most Recent
Xerox WorkCentre 3210 - Multifunction - B/W - laser - copying Questions & Answers
Xerox WorkCentre 3210 invalid toner
Verify you are use OEM Xerox Toner. If so, try reboot the unit, take out and reseat the toner. If that doesn't fix it you'll have a bad main board and will need to be replaced.
Would you please tell me how to reset xerox workcentre 3210 cartdridge chip?
Hi Marco,
They have a chip in them and can't be fooled so to speak by topping them up.
You can get toner and chips off ebay if you do a search for your model...
refer to link for an example...
http://www.ebay.com.au/itm/Hi-Yd-Toner-Refill-Reset-Chip-for-Xerox-WorkCentre-3210-3220-106R01487-/261253227411
Xerox workcentre 3345 paper jam in tray1
If you've modified one of the trays and still encounter the same error, it's worth checking if there are any obstructions in the paper path or if the default paper type and color settings need adjustment.
Remove Jammed Paper From Tray 1:
First, remove any paper from the Bypass Tray.
Grasp both sides of the Bypass Tray and pull it straight out of the printer.
Next, pull out Tray 1 until it stops. To remove the tray, lift the front of it slightly, then pull it out of the printer.
Check for any jammed paper and remove it.
Also, make sure there's no crumpled paper left in the tray or jammed inside the printer.
If you have Tray 2 (optional), check it as well.
Insert Tray 1 back into the printer and push it all the way in.
Fully insert the Bypass Tray as well.
Confirm the paper settings if prompted.
Try your job again.
Power the Printer Off then On:
Press the Power/Wake button on the printer control panel.
Choose "Power Off" to turn off the printer.
Wait for a few seconds, then press the Power/Wake button again to turn it back on.
Retry your print job.
Replace the Paper Feed Roller (if needed):
If the issue persists, consider replacing the paper feed roller. Refer to your printer's documentation for instructions on how to do this.
If the problem continues, contact Xerox support.
