20 Most Recent
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Questions & Answers
Dishwasher does not dry the dishes thoroughly
I have a GE dishwasher with poor drying. One service call said to make your water hotter and us a jet dry rinse. Not any better. Another call went to GE, this time they have a vent kit to help push out the steam and the computer will be reprogrammed to allow a longer dry time. Will have this done when the parts arrive at my home. Then the repair man will install and make computer adjustments. Looks like GE knows they have a problem but won't fix it until you complain more than once and demand a fix.
For all GE dishwasher owners with this problem start calling the customer service.
Dishes have a white film
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...Dishwasher
SprayArms not SpinningHow to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenanceDishwasherResidue and Film on Dishesheatman101 Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sometimes the soap dispenser does not open. How
Sometimes the soap dispenser is blocked by a large item. It could be a casserole dish, baking pan, etc. Be very aware as you load your lower shelf so that there in nothing that will block the action of the dispenser.
To remove the white build up, run a regular cycle when the dishwasher is empty. Instead of using detergent, use 1/2 cup of white vinegar. This should break down the white scale. After the final rinse, if there is still evidence of the scale, use an old toothbrush to scrub it off.
I hope this helps you. If it does, please come back to Fixya and rate my advice!
My dishwasher has locked all of the control
Hello, Thank You for using FixYa. I will be helping you today.Try holding it longer and if that dont work you might have a bad touch membrane.
Thank You and please rate my answer if it was helpful..
Our dishes and cutlery are coming out with a white
Dishwasher
How to Buy
heatman101
Dishwasher will not drain, model
if this is a new dishwasher it could have some plastic caught around the drain screen from packaging or if it dumps though a disposal and the disposal is new there is a little black plug that must be removed before the water will pass through the plug has to be removed with a hammer and a screwdriver the plug is located inside where the drain hose hooks to the disposal hope this helps
Has power, nothen works
Hello &
Welcome to FixYa
If it has
power but nothing is working then first check the control, if the lights are
there on the control, then try to hear if the motor is running and if it does
fill with water. If it fills with water and you hear a humm/buzz sound from the
bottom panel then it is the motor that is bad and needs replacement. If it is
completely dead then it is the main board also known as the electronic control
that is bad and needs replacement. Please get back to me if you have any other
questions.
Kevin
