20 Most Recent
Yamaha Rx-v465/rxv465 Home Theater Receiver Questions & Answers
Yamaha AV Receiver RX-V465 picture but no sound.
Check the settings on receiver in the SETUP menu / HDMI / Audio. Here you can choose Amp (sound goes from the speakers connected to receiver), TV (receiver is muted and sound is routed via HDMI to TV) and Amp+TV (sound goes from speakers and also to TV).
Also check in OPTION menu / Signal Info that receiver is receiving sound in recognized format.
1/17/2017 6:55:00 AM •
Yamaha...
Answered
on Jan 17, 2017
I have a Yamaha Rx -V465 AV receiver When turn the system on it will not stay on. I switch outlets it would do the same.
First disconnect all speaker cables and all input cables (optical, HDMI, everything expect power). If receiver powers off itself immediately even without anything connected, it is faulty and you need to send it for repair.
If it works without cables, then you probably have bad cables and/or short-circuit in the speaker connection and receiver is turning off to prevent damage. Double-check your connection and that no speaker "+" cable has a contact with any "-" cable or connector. Even one little strand of cable touching the opposite polarity connecter is enough to cause a short-circuit.
11/26/2014 1:14:52 PM •
Yamaha...
Answered
on Nov 26, 2014
Having trouble syncing audio with my new led tv. I
Normally you would to the TV settings under audio you would have to disable the tv audio and point it to your receiver I assume you have a surround sound. Make sure you are also using the right audio cable RCA or digital optic cable
10/24/2013 6:35:56 PM •
Yamaha...
Answered
on Oct 24, 2013
IS YAMAHA AMPLI RX SERIES RIPP OFF
Maybe the problem is with your speakers. Shorted speakers or speakers that are being over-driven can cause the receiver to shut down and possibly be damaged.
5/21/2013 8:22:54 PM •
Yamaha...
Answered
on May 21, 2013
