20 Most Recent Sony DAV-DZ810 Theater System Questions & Answers
STOP and EJECT combination together on the DVD remote ought to resolve
Sony DAV-DZ810... | Answered on Mar 22, 2016
Please check the connections TV - o/p and DZ810 - I/P ports..!!
Sony DAV-DZ810... | Answered on Apr 02, 2015
Put your dvd player on a power bar and just turn the power off to it.
Sony DAV-DZ810... | Answered on Jun 13, 2014
Try a different HDMI cable and if the sound doesn't come out,you'll have to get a qualified service personnel to check the audio stage of your tv for defective components of replace complete board.
Sony DAV-DZ810... | Answered on Dec 22, 2013
Slack pulley rubber may be the cause.This can only be fixed by a qualified technician.
Sony DAV-DZ810... | Answered on Oct 21, 2013
Go ahead with the latest version i.e. DZ84K. You will have the latest technology.
Sony DAV-DZ810... | Answered on Aug 25, 2011
Hi,here is my simple solution...
If you want to listen your TV on your Stereo system thru your receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the Receiver..By this means whatever you watch on the
TV (
tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Sony DAV-DZ810... | Answered on Jun 23, 2011
using the ordinary audio cable
Sony DAV-DZ810... | Answered on Apr 25, 2011
The only way is to buy a mini head phone amplifier and connect it to the audio out of the system. Even better is to buy a cordless headphone system. Available between 20 to 50 $
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=cordless+headphones&x=13&y=12
Sony DAV-DZ810... | Answered on Mar 17, 2011
You aren't syncing it with the TV unless you want to use the remote to turn the TV on and off. Check the instruction manual, you want to sync it with the home theater box. I would also check the batteries to make sure they aren't dead. Beyond that, if syncing it to the box doesn't work, take a look in the manual for troubleshooting an unresponsive controller. It could also have defective hardware.
Sony DAV-DZ810... | Answered on Jan 18, 2011
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Sony DAV-DZ810... | Answered on Jan 10, 2011
Hi Mark, check that the fiber optic cable is not damaged, has no breaks in its extension
replace and test with another cable, if the fault continues, check the audio input assignment in the Bar
I hope you can solve it
Regards Franco Dosil
Hola Mark, controla que el cable de Fibra ?ptica, no se encuentre da?ado, que no tenga quiebres en su extensi?n
reemplaza y prueba con otro cable, si la falla continua, revisa en la Barra la asignaci?n de entrada de audio
Espero que lo puedas resolver
Saludos Franco Dosil
Sony Audio... | Answered 3 days ago
Sony DAV-DZ810 Theater System Logo
20 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
kindly provide option
  • Audio Players & Recorders
