20 Most Recent Samsung HT-P10 Theater System Questions & Answers
0answers
0answers
0answers
My samsung ht-p10 home theater system displays "No Disc"
..I would assume that you have carefully cleaned the lense and inspected the flexible ribbon cable..try replacing the spindle motor..in our case they are not expensive..good luck Elben
11/16/2012 1:49:04 PM • Samsung HT-P10... • Answered on Nov 16, 2012
The lazer leans not working
If this is confirmed then the OPTICAL HEAD must be replaced with the same type. Before this is done you can clean the lens as a last attempt.
Use all precaution when replacing the head, need to remove the static shorting in the new head before replacing. Take help.
9/10/2011 3:20:04 AM • Samsung HT-P10... • Answered on Sep 10, 2011
My samsung ht-p10 theater system
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
2/6/2011 11:27:05 PM • Samsung HT-P10... • Answered on Feb 06, 2011
How to open the Samsung HT-P10 Subwoofer
samsung ht-p10 subwoofer not volume
2/1/2011 9:23:47 AM • Samsung HT-P10... • Answered on Feb 01, 2011
My HT-P10 displays "protection" and
The amplifier has a bad channel or is bad in general, and will need replacing. In some cases, it's a separate board and can be replaced itself, but in others, everything is on one board(except the power supply unit) and warrants just having he unit replaced.
12/4/2010 7:22:20 PM • Samsung HT-P10... • Answered on Dec 04, 2010
I have sound when i play a dvd but no picture
What connection are you using to connect the theater system to the TV.
Direct video cable or component video Pr, Pb and Y inputs?
Refer page 13 of the manual. (scroll down to enter verification code provided for download)
You will also have to make sure the TV setup is selected for the correct connection both on the Theater system and the TV. Refer page 33 of the manual.
It might help me to provide a clearer idea if you also mention the make and model no. of your TV. Did this work before?
Please rate the solution if you found it helpful or post a comment if you want further assistance.
10/8/2010 11:29:51 AM • Samsung HT-P10... • Answered on Oct 08, 2010
I Have samsung HT-P10, Pl
Hi.. my home theater system HT-P10.... is not working.... Any of its function do not respond after it being kept on...! Any of its function are not working.... the dvd player doest open up.. nor sound comes out of auxiliary, radio or any other function... and the 5.1 display is never shown.. it shows 2 channels only..
and this had been the problem frm last 1year.. at the beginning of the year... it was working suddenly in between and at times it use to turn out inactive but from last 6-7 months it is totally inactive...!
I contacted samsung.co.in and the guys came down to my house telling that we dont hold any spare parts of system we cannot do anythin...a do they say we do not repair...!
So what to do to repair it.. can it be..? nd can i ever use its sond sytem only.. in any form.?
10/2/2010 3:22:19 AM • Samsung HT-P10... • Answered on Oct 02, 2010
Samsung HT-P10 Theater System Logo
31 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
ht p10 displays protection
  • Audio Players & Recorders
