Collect together the manuals or model numbers of all the items you want the universal remote to control. You will need to know manufacturer's name and the model number of the product. You will also need the owner's manual for the Universal Remote
Find the codes for the devices that you want to operate. The codes are located in the Owner's manual for your remote. Be sure to match the codes up with the exact model number of the item that you are trying to operate. Each item must be set up and programmed into the remote individually.
Program the devices by this guideline for the process. These will be different with each model of remote chosen but this is the general procedure, so you know what to expect. To program a TV into the remote perform the following: Press and hold the code button on the remote until it stops flashing. Press and release the Code button and select the device this is for, and enter the three digit code for the manufacturer and model number of your device. With the device on, press the Channel UP key and see if the channel changes. You are done with that device if the channel changes. Repeat the process for each of the other devices.
Turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the SETUP button until the red
indicator remains on, then release SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((or POWER or
PLAY (VCR only)) repeatedly until the device to be
controlled changes channel. The red indicator blinks
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
OK.
35 questions posted
1,061 Questions
920 Questions
867 Questions
724 Questions
662 Questions
