20 Most Recent Konica Revio KD-310Z Digital Camera Questions & Answers
3answers
Accidentally deleted photos from sd
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones:
7/22/2015 5:12:38 AM • Konica Revio... • Answered on Jul 22, 2015
Hello my sony cyber-shot camera
Please try and download the driver from the following link:
www.ca.konicaminolta.com/support/americas/digital_cameras/???konica/revio_???kd310z/???
9/28/2010 7:56:58 AM • Konica Revio... • Answered on Sep 28, 2010
CAMERA GIVES AN "SYSTEM ERROR S0041" MESSAGE
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/27/2010 6:51:56 PM • Konica Revio... • Answered on Sep 27, 2010
My camera lens wont close and says system error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
9/11/2010 5:36:21 PM • Konica Revio... • Answered on Sep 11, 2010
System error s0041
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
8/29/2010 11:34:42 AM • Konica Revio... • Answered on Aug 29, 2010
Konica digital revio kd 310z was dropped and shows error s0042
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
4/14/2010 8:36:05 PM • Konica Revio... • Answered on Apr 14, 2010
2answers
System Error SOO41
Minolta Dimage G500 My lens is jammed in, and cannot eject itself or focus. It keeps on stating SYSTEM ERROR SOO41. Can you please let me know what i can do.
11/15/2009 4:38:52 AM • Konica Revio... • Answered on Nov 15, 2009
My konica revio kd 310z got an error and seems to
Well first of all you check both of the memory for pics, camera memory and the card (data card) memory.
If the pics are not on both of the memory locations it means the pics are corrupted from the memory location, If you need the pics then you can try to recover them using some recovery software (you also need a computer to recover these files). There are many chances, that the card of your camera is corrupted. so, if this error comes again you try replacing the memory card.
post further comments for more information.....
Good Luck!!
Thanks
9/17/2009 10:14:41 AM • Konica Revio... • Answered on Sep 17, 2009
Downloading pictures
Ya This is a VERY old camera (over six years old) and uses a memory card that is no longer made.
You can try calling the Sony help line 800.222.SONY and see what they say, but I am afraid you have been had.
Look here for a good, inexpensive P&S camera and avoid buying on eBay.
http://www.dpreview.com
10/14/2008 9:31:51 AM • Konica Revio... • Answered on Oct 14, 2008
2answers
Dropped camera
Buy the next one
Repair will cost nearly as much as a new camera
5/16/2008 2:38:40 PM • Konica Revio... • Answered on May 16, 2008
2answers
Unable to download pictures from camera to pc
i cant upload pic to my comuter from my camra when i incert the memory card it sayys incerst drive F?
what do i do?
2/25/2008 5:24:45 AM • Konica Revio... • Answered on Feb 25, 2008
Usb cord
There are currently four of them on eBay
2/15/2008 12:21:54 AM • Konica Revio... • Answered on Feb 15, 2008
I have a Konica Z-up 70, and it hardly turns on. I have a new battery in it and the date on the back comes on, but not the camera. It has worked twice randomly, but other than that wont turn on
It sounds like there could be an issue with the power supply of your Konica Z-Up 70. I suggest trying to reset the camera by removing the battery and then replacing it and turning it back on. If the issue persists, you may need to contact a qualified technician for further assistance
1/29/2023 11:17:19 PM • Konica Cameras • Answered on Jan 29, 2023
Is Konica Revio KD-420Zstill usable
If undamaged, with a fully-charged battery and the correct recording media - probably. This answer also applies to your other queries, although as it was last produced in 2004, you will be unlikely to be able to obtain a new one.
7/10/2019 8:12:04 PM • Konica Cameras • Answered on Jul 10, 2019
I cannot get my konica
Hi
the following memory types are supported byt your camera
SD (Secure Digital) Memory Card / MultiMediaCard (MMC) / Memory Stick / Memory Stick Pro
Do you have a card reader on your computer? We could format the card on the computer and then see if it works with the camera.
Can you tell me the size of the sdcard?
To format the card on your computer plug it into the reader, open my computer and find the card from there, ones you have found the right one from my computer right click and select format, Try formating the memory card to fat 12 or 16 and then when the format is complete insert it into your camera again.
(turn off the camera, insert the card, turn the camera on)
If the memory card still doesn't work plug it to the computer again and this time format it to fat32.
If this ia new sd card with alot of storage do you have a smaller card that already works on the camera?
4/13/2009 3:30:03 PM • Konica Cameras • Answered on Apr 13, 2009
0answers
0answers
Konica Revio KD-310Z Digital Camera Logo
18 questions posted
Top Konica Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Konica Camera Expert? Answer questions, earn points and help others
View Most Popular
Revio Konica
  • Revio Konica
Most Popular Question
accidentally deleted photos from sd
  • Cameras
