20 Most Recent Kenwood DPX303 CD receiver Questions & Answers
0answers
Where does the orange and pink wire go to dpx303
Hi there,You have only provided us with details on your Kenwood Receiver, but not the vehicle make or model.Therefore, I can only answer based on the Kenwood receiver wiring.The Kenwood receiver loom has an ORANGE (White stripe) wire - this connects to your vehicle's "Dimmer" control wire.Kenwood receiver loom does not have a Pink wire.Hope this helps.
3/14/2013 8:41:00 AM • Kenwood DPX303... • Answered on Mar 14, 2013
I need the wiring diagram
Hi,Would the Instruction manual help?images.kenwood.eu/files/prod/933/5/DPX503U_303_313_EN1.pdfHope this helps.Thanks!
1/6/2012 9:51:07 AM • Kenwood DPX303... • Answered on Jan 06, 2012
My unit went into protect mode randomly while i
you probably blew either a speaker or the output ic in the radio.
1/3/2011 7:50:11 PM • Kenwood DPX303... • Answered on Jan 03, 2011
A installed the kenwood dpx303
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote) instead of the blue/white wire (amp remote turn on) to turn your amp on. the antenna remote turns off when leaving tuner mode.
12/8/2010 5:11:17 PM • Kenwood DPX303... • Answered on Dec 08, 2010
Kenwwod DPX303 dead
There may be multiple fuse boxs in your car, you need to make sure to check all of them listed in your owners manual. Checking involves a voltmeter and not just checking the 2 fuses you think supply power to the radio, there may be multiple fuses that supply the necessary power to the radio. Yellow and red at Kenwood need to see 12 volt positive with the key on and the black needs to have ground in order to turn on. If all three have correct voltage then pull the harness from kenwood and check small 10 (red) or 15 (blue) fuse held in and protected by the harness. Good luck!
2/28/2010 3:59:00 PM • Kenwood DPX303... • Answered on Feb 28, 2010
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
I have 2 mtx 12"woofers (8ohms each wired parallel to get to 4ohms) which Kenwood amp would be best to use: kac-7252 or kac-9104d?
The Kenwood KAC-7252 and KAC-9104D are both great amps, but they have different strengths and weaknesses. The KAC-7252 is a 5-channel amp that can output 75 watts per channel at 4 ohms. It also has a built-in crossover and time alignment, which can be helpful for getting the most out of your woofers. The KAC-9104D is a 4-channel amp that can output 100 watts per channel at 4 ohms. It also has a built-in subwoofer output, which can be used to power a separate subwoofer. If you are looking for an amp that can power all of your speakers, the KAC-7252 is a great option. It is also a good choice if you want an amp with built-in crossover and time alignment. However, if you are looking for an amp that can power a subwoofer, the KAC-9104D is a better choice. It is also a good choice if you want an amp with more power output. Ultimately, the best amp for you will depend on your specific needs and budget. If you are not sure which amp is right for you, it is always a good idea to consult with a professional car audio installer. Here is a more detailed comparison of the two amps: Kenwood KAC-7252
  • 5-channel amp
  • 75 watts per channel at 4 ohms
  • Built-in crossover and time alignment
  • MSRP: $399
Kenwood KAC-9104D
  • 4-channel amp
  • 100 watts per channel at 4 ohms
  • Built-in subwoofer output
  • MSRP: $499
I hope this helps!
12/13/2023 2:44:37 PM • Kenwood Car... • Answered on Dec 13, 2023
3answers
- Kenwood KDC-X396 the Brown mute wire gets connected to what to get the phone to work through it
whatever makes it mute from whatever it is you are in
12/5/2023 7:21:12 AM • Kenwood Car... • Answered on Dec 05, 2023
MANUAL for kenwood dpx-6200m
12/5/2023 6:53:47 AM • Kenwood Car... • Answered on Dec 05, 2023
Kenwood DPX303 CD receiver Logo
Popular Tags
10 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
orange pink wire go dpx303
  • Car Audio & Video
