20 Most Recent
Alpine CDA-105Ri CD Players Questions & Answers
I AM UNABLE TO RE
If you want to acquire channels on your sat radio just make sure the Ai-net interface adapter is properly connected on your serious satellite radio tuner.
Press [SOURCE] / (I) button to activate the SAT radio mode
Press BAND to select one of the three SAT radio preset bands
Press button to select desired category
Press I<>I to select the desired channel
Holding down I<>I will change channels continuesly
try this and let me know.
I just installed my lightly used alpine cdA
are you using an amplifier? if so, you may be using the blue wire (antenna remote turn on) instead if the blue/white wire (amplifier remote turn on) to turn the amplifier on. the antenna remote turns off when leaving tuner mode.
It says mp3 but i
the mp3 refers to the deck being able to play cds burned in mp3 format.
I need to download a
You can download and print the instruction manual for Alpine CDA-105 in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe Reader Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
My alpine head unit is
reset your ipod by holding menu and center button for 10 seconds or its the menu and play button on some ipods. yours probably downloaded something off net and now just needs to refresh like a computer
Just purchased a cda105, the
the problem is that you are not turning on the amplifiers,
pull the radio out there are 2 blue wires, you are using the wrong one
just switch them and the cd and ipod will work
good luck
I have an alpine cda-105
Try switching off the iPod and then re-connecting it to your Alpine head units USB port allowing that to power it on. This will re-initialize the handshake between the two components and this should clear up the quit
Problem with the radio
THe frequency stepping cannot be changed on this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
