20 Most Recent
Sony Ericsson HBHPV708 708 Bluetooth Headset Dark Questions & Answers
When i switch on the
Step one: set your headset to "discoverable."
This is usually done by turning it on while pressing the volume up button. An alternative way is to press the volume up button and call button simultaneously. You are successful when the headset LED blinks differently.
Step two: turn on phone's bluetooth. Do a search for devices. Click on the one you want.
Step three: default PIN code is usually "0000"
Regards
Hbhpv708 when i press any
Hi, Before any bluetooth will connect to any phone, the red or red and blue light must flash back and forth. Make sure you're phone is in the set-up mode to recognize the phone. The easy way to do this if you dono't have directions, is to get the name and numbers off of the bluetooth and go online to find it. It will walk you through the steps to connect it to your phone. I have done this with many different models if all else fails. Give it a try and let me know what happens. This will solve you're problem,
Shastalaker7
Sony Ericson 250i Headset not recognised
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
