20 Most Recent
LG HBM-310 Bluetooth Headset Questions & Answers
Manual
usual charging time of these headsets is 2-4 hours
Hbm-310 manual
If you're connected, all you have to do is press the large end of the surface and it will answer the call
Need teh password
most passwords for blue tooth devices are as follows 0000,1234,1111 or 9999 i hope this helps
I am looking for a
http://www.lg.com/uk/mobile-phones/mobile-phone-accessories/LG-bluetooth-headsets-HBM-310.jsp
On the right side you can download the manual
How do i pair this
you must put the device into pairing or discovery mode then search or add new device from your phone menu once they have discovered or paired you will need a 4 digit pin or pairing code ,Most blue tooth device manufactures use the following codes 0000,1234,1111,or 9999 i hope this helps
LG HBM 310 will not
You must put your headset in pairing mode first. Starting with it turned off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards,
Carlos
Pass key mssing
It's '0000' (four zeros). If you need further details on how to pair it with your phone, you must put your headset in pairing mode first. Starting with it turned off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Regards,
Carlos
I CAN'T SEEM TO PAIR
Regards,
Carlos
I need the numeric passkey for the LG-310
Regards,
Carlos
I lost instructions on how to pair my lg bluetooth
You must put your headset in pairing mode first. Starting with it turnedd off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the HBM-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them within each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Regards,
Carlos
It will not pair up
You must put your headset in pairing mode first. Starting with it turnedd off, press and hold the power button (on its side), until the indicator light is steadily lit in blue (make sure you don't release the button when the light starts to flash as if the headset was being turned on). Only then, make your phone search for new devices. After a while, the GMB-310 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There might be an indication that a bluetooth headset is connected, too. The pairing process between any two bluetooth enabled devices should be performed only once. All subsequent connections between them should be achieved simply by bringing them with each other's range (with their bluetooth radios turned on, of course). At most, a simple press on the call button should suffice.
Regards,
Carlos
