20 Most Recent Jabra SP5050 Bluetooth Headset Questions & Answers
I can not pair the
You have to put the speaker phone into pairing mode it is meant to enter pairing mode automatically but from what you are saying it has not done this or has timed out. Press the answer /end button for 7 seconds to force the speaker phone to go into pairing mode then ask the phone to discover bluetooth devices. https://www.manualslib.com/manual/364943/Jabra-Sp5050.html?page=7#manual
7/5/2017 11:43:41 AM • Jabra SP5050... • Answered on Jul 05, 2017
0answers
How do i connect my Jabra SP5050 to a new phone.
Kako se povezati sa telefonom nokija E52
9/23/2013 7:12:14 PM • Jabra SP5050... • Answered on Sep 23, 2013
I have a Jabra SP5050 hands free device for the
Press and hold the button on the Jabra for 10 seconds until the LED starts blinking. This puts the headset in "discoverable" mode so the new cell phone will be able to see it for pairing.
If your phone prompts you for a pairing code, try either 0000 (four zeros) or 1234
9/19/2011 2:07:30 PM • Jabra SP5050... • Answered on Sep 19, 2011
Hello, i cannot pair my jabra
To get the Jabra SP5050 into pairing mode: Start with the unit turned off Press and hold the answer/end button Hold until the light starts blinking constantly, without pauses Release the button - this is pairing mode Your phone should be able to "find" it when it's in this mode.
5/17/2011 4:22:05 PM • Jabra SP5050... • Answered on May 17, 2011
How do u get it in the pairingmoode
Turn off the Jabra SP5050 by pressing the answer button for about 5 seconds; then turn it ON by pressing it 7 seconds (contrast to the normal turn ON with fewer seconds - the bluetooth light should flash continuously) Now the speaker is in manual pairing mode; use the phone's normal discover bluetooth to locate it.
4/27/2011 3:20:24 AM • Jabra SP5050... • Answered on Apr 27, 2011
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
2/18/2011 2:44:15 PM • Jabra SP5050... • Answered on Feb 18, 2011
Can't pair or connect Jabra
My Xperia X10 cant find my handsfree device nokia BH 105. Please help.
2/1/2011 2:52:43 PM • Jabra SP5050... • Answered on Feb 01, 2011
How to connect to phone
Depending on the phone, you need to enable bluetooth. then according to the directions on the Jabra, set it to "pairing" mode. Use the phone in the bluetooth menu to "find devices". Once it finds the Jabra you should need to enter a code to "pair" it, should be 0000 ( all zero's). Once paired, it should connect each time you turn the headset on.
12/31/2010 4:47:32 PM • Jabra SP5050... • Answered on Dec 31, 2010
Jabra SP 5050 LOst
The best what you can do is to go to the manufacturers webpage and from their you can download the software yo need and if you want o make a disc you can burn it in a disc.
8/13/2010 11:31:51 PM • Jabra SP5050... • Answered on Aug 13, 2010
Want to connect to a
Your phone then asks if you want to pair with it.Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the pass- key or PIN= 0000 (4 zeros).Your phone will confirm when pair ing is complete.
2/16/2010 11:03:34 AM • Jabra SP5050... • Answered on Feb 16, 2010
I have got a new phone and i am trying to pair my
try to push the headset on button till the light stop flashing.
1/28/2010 11:23:29 PM • Jabra SP5050... • Answered on Jan 28, 2010
Unable to pair Jabra 5050 with Motorola qa1.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
1/5/2010 1:55:07 AM • Jabra SP5050... • Answered on Jan 05, 2010
Jabra sp5050 can you please tell me the factory
Try 0000! It's the standard bluetooth code for most bluetooth enabled devices unless changed.
10/29/2009 11:52:58 PM • Jabra SP5050... • Answered on Oct 29, 2009
Jabra talk 15 how to change the battery
See the video. Getting them open without breaking the locking tabs is the hard part. You need good Spudger skills. https://www.google.com/search?q=jabra+talk+15+battery+replacement ..
2/26/2022 5:57:06 PM • Jabra Radio... • Answered on Feb 26, 2022
Good day! How do I change my language option to English on my Jabra F600.
How do I change the voice guidance language? ' Jabra ...
https://www.jabra.com > ... > Frequently Asked Questions
Connect your Jabra device to a computer. · In the Updates section on the product support page, select the firmware language and download the file. · Open the file ...
6/12/2021 2:44:18 PM • Jabra Radio... • Answered on Jun 12, 2021
How.do.i get my jabra extreme 2 speak englidh
They are sold with the firmware and language for the country they are selling to. You have to change the firmware to your country. Easy to do with a computer.
To change the language of your device, you must upgrade the firmware with the ... How do I manually turn off/on voice guidance on my Jabra Extreme2?How do ...
Jabra Extreme 2 ' Jabra Support
www.jabra.ca > Support > Jabra Extreme 2
Get support for your Jabra Extreme 2. Find all product guides, resources and FAQs.
What is voice guidance? ' Jabra Extreme 2 ' Frequently Asked ...
www.jabra.ca > ... > Frequently Asked Questions
How do I reset my Jabra Extreme2?How do I pair my Jabra Extreme2 with my mobile device?How do I update the firmware or change the language on my Jabra ...
2/26/2021 5:00:03 PM • Jabra Radio... • Answered on Feb 26, 2021
Jabra SP5050 Bluetooth Headset Logo
30 questions posted
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Jabra Radio Communications
Most Popular Question
cannot pair jabra
  • Radio Communications
