20 Most Recent
JVC Everio GZ-MG230 Camcorder Questions & Answers
I need the operating manual
You can download and print the instruction manual for JVC Everio GZ-MS230AU in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
I can't find my cable
You need ["A" type (left) to Mini-"B" type (Right) connector. Universal Serial Bus (USB) cable] to transfer picture/ movie files in computer.
This USB Cable is available with
JVC Accessories Store for $11 however, you can buy it in local store as well.
Check camcorder for USB Port that will accept USB Cable jack.
Let me know if you have additional question.
Thanks.
When i connect my can to pc i can't see any thing
Connecting Everio to PC behaves like as you are connecting an external HDD to your PC. You can just transfer files from you Everio(SD Video folder for videos,DCIM for photos) files with extension .TOD or .MOD sometimes can't be open depending on you pc.Just rename those to .mpg(note; make a back up since this process is ereversible). If you did installed the application software provided, wait for a while after connecting, and it will pop up, ready to use. Note: some everio models will promt you what to do after connecting, just click the desired option. Good Luck
I cannot find my installation cd? What can I do so
If you don't have a manual, go to the following internet location:
http://books.jvc.com/booklist.asp?Model=GZ-MG230
then click on the underlined "Instruction Manual". On page 27 it shows how to backup your files on the PC without software.
Power not on or USB device not compatible
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
I can not access the menu on my jvc everio gz-mz37u to reformat the hard drive and HDD error is still showing, please help.
first of all my advice is: if you keep any electronics devices without usage for a long period, you must detach the battery/power supply.
in this case I think the hard disk may be faulty, if you can open the camera and takeout the HDD connect with an HDD dock connect the dock to your system, in normal condition your computer will detect the hard disk, if so you can save the contents to your computer or you can format it, if it is not detecting your computer it means the HDD is physically damage. please change it.
Everio media browser 3 be
I solved my problem by changing the setting from PAL to NTSC in the Everio media browser (the unit was purchased in the US but the software was set to PAL).
