20 Most Recent JVC GY-HM100U High Definition Camcorder Questions & Answers
Hi there seems to be a problem with the iris to my
See if you can reset camera to factory defaults. If not then you have a serious issue with the camera electronics. Think that puppy is ready for retirement since repair, if available, will cost a small fortune and not be worth it.
9/20/2017 2:07:14 AM • JVC GY-HM100U... • Answered on Sep 20, 2017
0answers
LCD screen not working, how do I format SD cards or access other menu items?
remove SD Card, insert into adapter and format on laptop or computer.
11/12/2014 8:14:32 PM • JVC GY-HM100U... • Answered on Nov 12, 2014
Hello guys, please only reply if you have a
When was the last time you white balanced your camera? I can't say for certain, but it sounds very similar to a problem I use to deal with all the time.
  1. set the ND filter according to the lighting
  2. set the WHT.BAL. switch to A or B
  3. locate a place with similar lighting conditions as the subject, place a white object near the center of the screen and zoom in to fill the screen with white
  4. press the auto white balance button
I got all of this from the manual. starting on page 35. I hope this turns out to be it. Let me know how it works out!
5/19/2014 1:57:37 PM • JVC GY-HM100U... • Answered on May 19, 2014
I have a jvc GY-HM100U High Definition Camcorder
The gy-hm100 can record to sdhc media up to 32gb in each slot (total 64gb). For best performance you must use class 10 sd cards. Your camera may need updated firmware that enables class 10 support so check the JVC Pro website and follow the firmware instructions if you haven't done so already. Also, make sure your card is formatted and unlocked with plenty free space. 4 gb is not much at all and a card that size may not be of sufficient speed to operate correctly in the gy-hm100.
5/18/2014 1:30:22 AM • JVC GY-HM100U... • Answered on May 18, 2014
I cannot open JVC MP4 files
Generally, camera shots vidoes in mod or mts format, so if you tend to play them or edit them on mac-based software, a easy way is transfer the format to another mac friendly format such as mov. take a look at How to Change Files from MOD to QuickTime MOV on Mac OS X
11/20/2012 1:44:13 AM • JVC GY-HM100U... • Answered on Nov 20, 2012
JVC HM100U auto exposure and image stabilization stopped working. Can control somewhat manually.
This is usually caused by a failed component in the power circuit within the camera. This will require disassembly and trouble-shooting to identify and replace the defective component and can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
10/21/2011 3:36:49 AM • JVC GY-HM100U... • Answered on Oct 21, 2011
Jvc GY-HM100u will not focus. I removed the lens
The most likely cause for this is a zoom or focus lens out of place or impaired in some way. This will require disassembling camera to remove the lens block and then disassembling the lens block to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
9/15/2011 10:38:13 PM • JVC GY-HM100U... • Answered on Sep 15, 2011
3answers
Jvc AV70BT production mode
You can exit production mode by pressing the menu and reset button. Simply press and hold the MENU button first then press and hold the small reset button. Keep both buttons down until the radio powers off and back on. Do not let go of the buttons until the radio comes back on and off production mode. You may also press the MENU and reset buttons repeatedly.
3/10/2024 6:13:37 PM • JVC Video... • Answered on Mar 10, 2024
The cassette is stuck in my JVC GR-D270. When I open it up it doesn't pop up or anything. Is there a reset button to make it pop out or is there a way to manually remove it?
The reason the tape is jammed in there is due to the mechanism not completing its routine and jamming. This can be caused by a worn/broken belt or even a motor supply or the motor itself. It needs expert hands to remove the cassette without damage.
2/6/2024 7:07:47 AM • JVC Video... • Answered on Feb 06, 2024
EO4 ERROR CODE FOR JVC GR-AX2U CAMERA
The mechanism is jammed. Probably due to its age.
1/23/2024 7:05:13 AM • JVC Video... • Answered on Jan 23, 2024
How to remove jvc av70bt production mode
Jvc kw-av70bt is in production mode some say you change it by pressing and holding menu and reset buttons
10/10/2023 9:07:46 PM • JVC Video... • Answered on Oct 10, 2023
We have a jvc camcorder gr-0771 keeps giving error 3 safeguard mode how do we get out of it.
Error 3 means the mechanism is stuck/jammed. Take it to a JVC Camcorder service agent.
9/26/2023 12:49:59 PM • JVC Video... • Answered on Sep 26, 2023
Wherecan I find a driver for JVC GR DX 37
Bearing in mind that this equipment coexisted with Windows XP, you can try emailing jvc suppport requesting the driver or venture into the quicksand pit of driver updaters. There you may or may not find a compatible driver, bearing in mind some updaters will claim to have a compatilbe driver up to and including Windows 11. Some forums suggest you don't need a special driver. other forum users say they have tried various drivers and not found them to work. And then there are those who claim the driver came out on CD. Would that leave you looking for an XP computer to run the driver upon? you would be chasing air to find a very recent laptop having a CD reader. I make no claim to knowing whether the following would work for you, given the original driver was XP compatible. i would make a restore point before even trying it; https://www.solvusoft.com/en/update/drivers/digital-video-recorder/jvc/gr-dx37/sub-models/ https://www.driverguide.com/driver/detail.php?driverid=1404220 https://forums.techarp.com/threads/jvc-gr-dx37-camcorder-driver.17415/ https://www.jvc.com/usa/support/
7/9/2023 5:24:01 PM • JVC Video... • Answered on Jul 09, 2023
JVC everio gz ms120 menu buttons no longer working
If you're experiencing issues with the menu buttons on your JVC Everio GZ-MS120 camcorder after adjusting the settings, there are a few troubleshooting steps you can try:
  1. Remove the power source: Disconnect the camcorder from any power source, including the battery and AC adapter. Leave it disconnected for a few minutes to ensure a complete power cycle.
  2. Reset the camcorder: While the power source is disconnected, press and hold the "Reset" button on the camcorder. The reset button is usually located in a small hole or recessed area and may require a small pin or paperclip to access. Hold the button for several seconds, then release it.
  3. Reconnect the power source: Reattach the battery or connect the AC adapter to the camcorder and turn it on. Check if the menu buttons are now responsive. If not, proceed to the next step.
  4. Connect to a computer: Use the USB cable to connect your camcorder to a computer. Once connected, some camcorders allow you to control and adjust settings through the computer's software or firmware update utilities. Try accessing the settings through the computer interface to adjust the display brightness or perform a factory reset.
  5. Contact JVC support: If the above steps don't resolve the issue, it's recommended to reach out to JVC's customer support for further assistance. They can provide specific guidance tailored to your camcorder model and help you troubleshoot the problem effectively.
Remember to provide as much detail as possible about the issue and the steps you've already taken when contacting support. This will help them provide accurate and efficient assistance.
6/18/2023 4:00:39 PM • JVC Video... • Answered on Jun 18, 2023
My JVC S800U Editing System will not power up. It has good power source.
This is a $3,500 machine, so professional repair only. Find a local JVC Service Centre. This is not a known issue and you are the only person with it. You tried a Power Reset? https://www.google.com/search?q=JVC+S800u+Editing+system%2C+no+power https://www.google.com/search?q=JVC+service+centre ..
4/13/2023 9:05:44 PM • JVC Video... • Answered on Apr 13, 2023
2answers
Play back on jvc video movie GR-A1E distorted
It is possible that the heads in your JVC video camera need cleaning, especially if the playback picture looks distorted and similar to a VHS tape played on a player with dirty heads. Dirty or worn-out heads can cause playback issues, including poor picture quality, distorted images, and tracking problems. To clean the heads in your JVC video camera, you can try the following steps:
  1. Purchase a head cleaning cassette: You can find head cleaning cassettes online or in electronics stores. Make sure to get one that is compatible with your JVC video camera.
  2. Insert the cleaning cassette: Open the tape compartment on your JVC video camera and insert the head cleaning cassette. Close the tape compartment.
  3. Run the cleaning tape: Press the play button on your JVC video camera to run the cleaning tape. The cleaning tape will clean the video heads as it plays.
  4. Eject the cleaning tape: Once the cleaning tape has finished playing, eject it from your JVC video camera.
  5. Test your tapes: Try playing your tapes again to see if the picture quality has improved.
If cleaning the heads does not solve the problem, it is possible that there is a more serious issue with your JVC video camera.
3/18/2023 9:07:17 PM • JVC Video... • Answered on Mar 18, 2023
How to fix Jvc GR-D239E safemode 06?
Safemode 06 on JVC camcorders usually indicates a problem with the tape transport mechanism. It could be a mechanical issue or an electrical issue. It's possible that the black rubber you found inside the camera was a part of the tape transport mechanism that came loose or broke off. It's also possible that there is some debris or dirt stuck in the tape transport mechanism, preventing it from functioning properly. One thing you can try is to clean the tape transport mechanism with a soft brush or compressed air. Be careful not to touch any of the delicate parts inside the camera. You can also try using a different tape to see if the problem is with the tape itself. If cleaning the tape transport mechanism and using a different tape doesn't solve the problem, it may be necessary to take the camera to a professional for repair. They will be able to diagnose the issue more accurately and determine if any parts need to be replaced.
3/18/2023 8:18:17 PM • JVC Video... • Answered on Mar 18, 2023
JVC GY-HM100U High Definition Camcorder Logo
12 questions posted
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GY JVC
  • GY JVC
Most Popular Question
seems problem iris
  • Video Cameras
