20 Most Recent RCA EZ300 Camcorder Questions & Answers
0answers
Camera not on
Be the first to answer 1/20/2013 4:35:10 PM • RCA EZ300... • Posted on Jan 20, 2013Be the first to answer
Its asking for the sd card to be unlocked and it
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
9/30/2010 9:36:12 AM • RCA EZ300... • Answered on Sep 30, 2010
Locks up
Thanks for using Fixya.
(i) Try to delete some items from your device.
(ii) Take out your memory card, battery and then again put them back.
(iii) Scan it with any antivirus.
If the problem still exists, you will need to take your device to the service center for possible internal faulty.
Good Luck and have a nice day.
5/19/2010 7:07:16 PM • RCA EZ300... • Answered on May 19, 2010
I need a manual for my ez300hd small wonder
Hello Sir.
Welcome to Fixya.
Please Download Your Manual from the Link Below:
RCA EZ300 Camcorder.
Thank You.
Good Luck.
11/8/2009 5:49:19 AM • RCA EZ300... • Answered on Nov 08, 2009
RCA CC604 VHCS Camcorder. My old camcorder won't record?
Question edited into written English with punctuation. The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders. I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder? https://www.google.com/search?q=RCA+CC604+VHCS+Camcorder+manual ..
2/11/2023 11:54:21 PM • RCA Video... • Answered on Feb 11, 2023
2answers
RCA CC433 will not record or play back tapes
Hi, You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player. Thank you.
11/18/2022 6:23:14 AM • RCA Video... • Answered on Nov 18, 2022
Vintage RCA Solid State Image Sensor VHS camcorder (Model Number CC275) wont record anything, or play back video. I’ve been putting in only new tapes with the tab intact, and every One simply refuses to record. I tried playing back an old vhs tape from like 30 years ago and while it did rewind, it didn’t play inside the camera. Does anyone know how I might be able to remedy This? Thank you in advance
I don't know anything about the vhs camera - other than they produce superior quality, when they work ok. It would be reasonable to assume the tape transport mechanism would be the same as in a vhs video recorder. I remember an engineer telling me there is a post or protrusion containing a light source and sensor that sometimes fails. The purpose of this is to detect a cassette has been properly loaded into the machine and if it isn't working the machine won't work or only partly work. I think the camera is worth saving but I strongly suggest such specialist equipment should be entrusted to a suitably experienced professional specialist.
3/2/2020 1:38:35 AM • RCA Video... • Answered on Mar 02, 2020
Looking for a RCA pro 8 camcorder Manaul
Do you have a model number? I found a manual for the RCA Pro8, Pro807, from Voxx here: https://voxxintl.zendesk.com/hc/en-us/articles/225487888-Information-and-Owner-s-Manual-for-the-RCA-PRO8-Model-PRO807-Camcorder . The direct link to this manual appeared as https://sc.voxxintl.com/docs/common/PRO807/PRO807_OM.pdf in my browser history. I hope this helps. Cindy Wells
9/9/2018 9:57:07 PM • RCA Video... • Answered on Sep 09, 2018
RCA CC9360 Steady Pix camcorder has grinding sound, jerky playbac
I am sorry to say that it appears you may have answered your own question, the "hundreds of hours" is the clue. Consider the possibility that your camera is worn out. Sorry.
12/12/2017 7:08:56 PM • RCA Video... • Answered on Dec 12, 2017
0answers
Rca camera
Be the first to answer 11/29/2017 12:04:56 AM • RCA Video... • Posted on Nov 29, 2017Be the first to answer
I have an RCA small wonder, does not load on my PC
It appears to have a built-in USB connector, use that.
11/10/2017 11:13:33 PM • RCA Video... • Answered on Nov 10, 2017
My cc275 vhs rca comcoder on camera will not focus are stay on rec for 2 second
I understand you have a problem. What is not clear from your description, however, is the actual nature of the problem. Please can you state it more clearly. Thank you.
6/15/2017 10:00:17 AM • RCA Video... • Answered on Jun 15, 2017
Cc275 vhs camcorder vhs rca rec will not say on 3min.
Won't say what ? Hello ? Goodbye ?
6/9/2017 8:35:38 AM • RCA Video... • Answered on Jun 09, 2017
0answers
Need a manual for rca camera
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
1/2/2017 10:43:55 PM • RCA Video... • Answered on Jan 02, 2017
RCA 4362 button will not work I dnt know what going on. Everything else works. The mic is still good. But when I put the tape in all I see is "Tape" and when I press the REC button nothing at all.
This was manufactured in 1999 - this makes it at least 17 years old. If I were you, I would wish it a happy retirement, and replace it with a more up-to-date camcorder with better optics, a digital image capture system, and which is far lighter in weight and more portable.
12/15/2016 11:27:02 AM • RCA Video... • Answered on Dec 15, 2016
RCA 4462 button will not work I dnt know what going on. Everything else works. The mic is still good. But when I put the tape in all I see is "Tape" and when I press the REC button nothing at all. He
RCA 4462 is actually the catalogue number for a vinyl LP by Brian Auger - are you sure you have quoted the correct model number ?
12/14/2016 12:24:12 PM • RCA Video... • Answered on Dec 14, 2016
RCA EZ300 Camcorder Logo
Popular Tags
6 questions posted
Top RCA Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
View Most Popular
RCA Video Cameras
  • RCA Video Cameras
Most Popular Question
its asking sd card unlocked
  • Video Cameras
