20 Most Recent Sony Handycam HDR-XR520V Flash Media AVC Camcorder Questions & Answers
2answers
Sony hdr xr520ve blinking E:62:10-12 - what should
Now you can get your answer in below table. In this case you have to replace board VC-57733dqjr0hm0waaaaasuvork5cyii=whum2nkfeow9aaaaabjru5erkjggg==E:62:10 Shift lens initializing failure.**** When the lens block was replaced, start the Adjust Manual in the Adjust Station and execute the necessary adjustmentitems.After the adjustment, make sure with the STEADYSHOT turned ON that the steadyshot functions appropriately in the handheld operation.Now you can get your answer.Kind regards.Rehan Zafar.
11/11/2018 9:19:08 AM • Sony Handycam... • Answered on Nov 11, 2018
0answers
After a rainday our Sony
The error code 95:00 indicates a problem with the cameras flash system and there is most likely some corrosion in the camera as well from the rain. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
8/17/2011 9:03:26 AM • Sony Handycam... • Answered on Aug 17, 2011
Sony HDR-XR520V will not allow me to export video
Can you see the camcorder as an extra drive? If you can, you can probably open it up to the DCIM folder and manually copy or move the pics and videos to a folder on your computer. If your new computer is running Windows 7, there may be an incompatibility issue, or some other conflict that will be hard to reconcile, without concerted effort and a lot of time.
The PMB utility may be corrupt, or the hard drive could have a bad sector, it's hard to say but entirely possible.
I would just work around it, if you can, and use the drive folder in Computer to transfer the files to a folder, if that works.
You might check with Sony for a patch if there is some incompatability with the program and your new computer, here's their support site:
http://esupport.sony.com/
Good luck, hope this helps, and thanks for using FixYa.
9/7/2010 2:50:08 PM • Sony Handycam... • Answered on Sep 07, 2010
tip
Where to find the manual (pdf) for Sony Handycam HDR-XR520V camcorder
Sometimes , it is convenient to have a soft copy of your user manual. You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please click HERE to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual. I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the link above. You will be taken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturer's contact page , please click on the relevant link below :
Kodak
Sony
Panasonic
Samsung
Fijitsu
Canon USA
Canon Global
Nikon
Phillips
Please rate this tip if you found it useful.
Kind Regards
StephanSA
Hard Drive Clicking
That is not normal. there is a scratch on the hard drive... try to put a new hard drive
1/14/2010 5:24:15 PM • Sony Handycam... • Answered on Jan 14, 2010
Sony DCRA-C162 Camcorder. I need a replacement battery for the DCRA-C162. Does anyone know where I can get one?
Question edited for clarity, add full 'make model (what it is)'. Question moved from Cars and Trucks category. Searching for your manual keeps bringing up this manual https://www.sony.com/electronics/support/res/manuals/2698/26988801M.pdf Looking at that manual Page 16, it states the battery pack as 'NP-FP50', and that turns up batteries for $15. https://www.google.com/search?q=NP-FP50 ..
11/20/2023 12:02:19 AM • Sony Handycam... • Answered on Nov 20, 2023
Sony Handycam CCD-TRV68 Flashing No Tape and Eject Symbol
If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test. Probably too old being 2001 vintage.
11/19/2023 12:20:58 AM • Sony Handycam... • Answered on Nov 19, 2023
SONY mini HandyCam model V569. HOW DO YOU TURN ON A SONY V569?
Question edited to add full model designation. Question moved from Sony Computers. This doesn't seem to be a very well known model. It is not even listed on their website. https://www.sony.ca/en/electronics/support/cameras-camcorders/manuals/results?query=V569# There are normally two batteries, a small one that just saves memory and runs the operating system, and a larger battery that actually powers the camera. Try contacting Sony direct There is a bit of help here, but not enough. https://www.google.com/search?q=SONY+V569 ..
8/4/2023 4:37:50 AM • Sony Handycam... • Answered on Aug 04, 2023
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
4/13/2022 7:57:16 AM • Sony Handycam... • Answered on Apr 13, 2022
Handycam CCD-TRV70 Hi8 camcorder. Why is it suddenly playing all tapes fuzzy, with no audio?
The record / playback heads probably need cleaning, using a compatible cleaning tape. Failing that, it is either damaged or broken.
1/5/2021 11:43:05 PM • Sony Handycam... • Answered on Jan 05, 2021
2answers
Blue screen on TRV260 playback
TRV260 nail-polish head attack: eek. Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation. Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum. Not to mention gumming up the bushes and bearings. With your next camera, rather use a head-cleaner DV-tape.
12/20/2017 4:11:58 PM • Sony Handycam... • Answered on Dec 20, 2017
Sony Handycam HDR-XR520V Flash Media AVC Camcorder Logo
14 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
after rainday our sony
  • Video Cameras
