20 Most Recent Sony HDR-XR200V High Definition AVCHD Camcorder Questions & Answers
0answers
HDR-XR200V
Be the first to answer 11/10/2013 5:00:07 AM • Sony HDR-XR200V... • Posted on Nov 10, 2013Be the first to answer
0answers
The zoom rocker switch on
This is most likely a defective zoom rocker switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
5/26/2011 5:24:39 PM • Sony HDR-XR200V... • Answered on May 26, 2011
I do not know how
You will need a card-reader (you plug it in your computer using USB). Then it shows up as a normal drive which you can access through 'My Computer'.
5/5/2011 8:20:53 AM • Sony HDR-XR200V... • Answered on May 05, 2011
My problem is blurry photos.
You haven't switched the camera to "macro" mode by any chance? Flash should eliminate camera shake as the source of the problem. If it isn't macro mode, then it sounds like a fault requiring the repair shop.
10/25/2010 9:39:33 PM • Sony HDR-XR200V... • Answered on Oct 25, 2010
I dont have the Sony HDR-XR200V High Definition
AVCHD video converter enables you to convert AVCHD to friendly video formats like avi, mpg, wmv, mp4, mov, flv, asf, rm so that you can easily work on them with Windows Movie Maker or Windows Media Player.
8/18/2010 11:39:04 AM • Sony HDR-XR200V... • Answered on Aug 18, 2010
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
8/17/2010 9:40:33 AM • Sony HDR-XR200V... • Answered on Aug 17, 2010
2answers
I CAN'T VIEW VEDIO CLIPS ON MY COMPUTER FROM MY
AVCHD stands for Advance Video Coding High Definition. Its a video format jointly developed by Sony and JVC. Windows pre-installed applications doesn't natively support this format.You would need the supplied software (Picture Motion Browser v.5) to playback or view your media files.Although it's possible to manually import files to your PC [Mac computers would need to have an intel-based processor, imovie'08 or '09, and NO SD (Standard Definition) FILES recorded to be able to transfer videos] still a you would need a mediaplayer software that supports and recognize AVCHD files for playback. AVCHD files are located in the AVCHD folder>BDMV>Stream. Files would have a .mts or .m2ts extension. So either you use the supplied software or invest on a AVCHD compatible video capturing or editing software.Hope this helps... (update may be released within this month for PMB v.5.2 but downloading orig software for this 2010 model cam, would be better to check this site (you can download PMB software if you don't have it): http://support.sony-europe.com/dime/camcorders/hdh/hdh.aspx?site=odw_en_GB&m=HDR-XR200VE
4/21/2010 2:39:11 AM • Sony HDR-XR200V... • Answered on Apr 21, 2010
How do I download my videos onto my computer..I
maybe you need to convert the files first. try to convert it to MP4 files, or MP3 files, or AVI. http://www.downloadvideos-convert.com/
3/13/2010 6:54:24 AM • Sony HDR-XR200V... • Answered on Mar 13, 2010
Hdr-xr200 always says it's overheated
an immediate replacement of thermistor... before your whole system collapse.
1/14/2010 4:12:14 PM • Sony HDR-XR200V... • Answered on Jan 14, 2010
Looking for user manual sony HDR XR200 video
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HDRXR200V
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
12/3/2009 2:37:27 PM • Sony HDR-XR200V... • Answered on Dec 03, 2009
Sony HDR TG3 Video Camera. The lens cover stuck closed
Question edited for a lot more clarity. Question moved to Sony HDR category. AI Answer Bot bad answer deleted.
Lens Cover Doesn't Open or Close Properly
Sony https://www.sony.com > electronics > support > articles Solution. The lens cover won't open if the camera's date and time isn't set. Set the date and time and perform a power cycle on the camera. ..
9/13/2023 12:11:17 AM • Sony HDR Video... • Answered on Sep 13, 2023
4answers
Best way to convert m2ts video format to mov format?
MTS and M2TS format is a Sony hd camcorders and Panasonic camcorders format.if you want to edit your video clips by imovie than you have to convert it to imovie suitable format.you can convert it mov format bfor edit.mov format is commonly use and most preferred for imovie.just download a good converter. http://www.aimersoft.com/convert-mts/convert-mts-m2ts-to-mov-mac.html
4/22/2020 3:25:23 AM • Sony HDR Video... • Answered on Apr 22, 2020
0answers
Owners manuel
You can download the manual you need here, free of charge: Sony HDR HC9 manual
1/18/2015 10:00:21 AM • Sony HDR Video... • Answered on Jan 18, 2015
Change from record to playback mode
If you need help alternating between the modes as well as adjusting any other settings, the user manual for the device should cover everything you need: Sony HDR HC9 manual
1/17/2015 6:44:59 PM • Sony HDR Video... • Answered on Jan 17, 2015
Yellow tint on display screen
hi you must have a broken wire in the flat ribbon of the LCD (the one for the blue colour). you have to replace it cheers mich
11/25/2014 11:53:55 PM • Sony HDR Video... • Answered on Nov 25, 2014
Sony HDR-XR200V High Definition AVCHD Camcorder Logo
25 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HDR Sony
  • HDR Sony
Most Popular Question
zoom rocker switch
  • Video Cameras
