20 Most Recent Whirlpool Cabrio WTW6800W Washer Questions & Answers
When I push the Start button it does not click or work?
change same
3/9/2015 12:38:45 AM • Whirlpool Cabrio... • Answered on Mar 09, 2015
0answers
LD ERROR CODE AND WONT DRAIN LID WILL LOCK
try any button sequences yet . try holding start button and a cycle button hold both down to reset
4/3/2013 1:57:54 AM • Whirlpool Cabrio... • Answered on Apr 03, 2013
How to add more water
You will need to replace the control assembly.
11/13/2012 1:44:41 PM • Whirlpool Cabrio... • Answered on Nov 13, 2012
0answers
0answers
Can you please let me
Actually the 'Cabrio' model, for some reason which I cannot fathom, does NOT have a filter which I have to say seems a bit strange! Maybe it is not practical/feasible (???).
It must be possible to be able to have the drain motor/pump checked 'cos that could be a bit blocked up???
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
8/1/2011 12:36:00 PM • Whirlpool Cabrio... • Answered on Aug 01, 2011
Whirlpool Cabrio he washer stopped
You may perform an automatic diagnostic test to check the machine functions and view any saved fault codes. Fault codes may also appear during the test when a problem is detected. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
7/20/2011 4:36:27 AM • Whirlpool Cabrio... • Answered on Jul 20, 2011
Getting code F50 service manual page 67
If you have been overdoing it with the soap or using incorrect detergent AND you have noticed that the washer takes a long time to finish a load I would lean toward a very tired and worn out RPS (rotary position sensor. If you use the correct amount of the correct soap religiously then I would lean towards objects between the tub. pop the cover off the nut remove the nut on the agitation pale and get it out then you can remove the tub and look for junk. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6/28/2011 10:56:18 PM • Whirlpool Cabrio... • Answered on Jun 28, 2011
Whirlpool Cabrio WTW6800W Washer Logo
42 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
Cabrio Whirlpool
  • Cabrio Whirlpool
Most Popular Question
when push start button not click or
  • Washing Machines
