20 Most Recent
Sagem My411x Cell Phone Questions & Answers
When someone tries to call
Open the call settings and scroll to see "divert all calls when busy" Now select "cancel all diverts " to reset the phone. You can also reset your phone to the default factory settings.
If this wont work call the service provider's call centre to confirm if there is a system divert activated to your voice mail.
What is the pin number to unlock my phone to used
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
No pc suite for sagem my214x
COMPARE THE DATA CABLE PIN SIZE OF YOUR MOBILE WITH OTHER MOBILE. SEE WHICH COINCIDES AND INSTALL THAT PC SUITE FOR USE. TRY THIS. IT MAY HELP YOU.
Have sagem my411x orange which has sim lock.the
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Simlok
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. I will suggest the website
Please, can you unlock my Vodafone SIM locked.
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
Hope this helps.
Unlock code
Hope this helps.
I want to have a sim free phone sagem my411x for
As far as I know free codes does not unlock your phone, so even if you would find a unlock code or whatever you'd have to spend some money.
I would recommend the
Unlock-Zone.com site is nearly perfect and they were recommended highly in the cell phone forums.
Hope this helps.
Elo...my sagem is asking for a phone
Hope this helps.
Need a free unlock code for a sagem my411c phone.
Hope this helps.
