20 Most Recent Jayco 2013 Jay Flight Swift SLX 154BH Questions & Answers
2023 Jayco SLX 195RB Travel Trailer RV. The bathtub is clogged. How do I unclog the water.
Question edited for clarity, correct 'make model' order and 'what it is', plus toss in some CAPS. Question moved from Home category, to Jayco. If it is 2023, it must be still under warranty? Or was it supposed to be 2013? Use a plunger. These are good, they can be used on sinks, baths and toilets. https://www.uline.ca/Product/Detail/H-2246/Toilet-Bowl-Brushes-and-Plungers/Industrial-Plunger? Or this sort that can suck and blow https://www.canadiantire.ca/en/pdp/plumbshop-plunge-it-toilet-plunger-0630886p.0630886.html?loc=plp If you have long hair and wash your hair in the bath, this is a great product that has a hair grabber to pull all the hair out of the plug hole. The crystals are good for keeping the pipes clean. https://www.amazon.ca/Green-Gobbler-Opener-Toilet-grabber/dp/B01DBMV7H8/ ..
7/21/2023 3:52:51 PM • Jayco 2013 Jay... • Answered on Jul 21, 2023
How does the large front blind work on a Jayco Prestige RV please?
Question moved to one of the Jayco categories. Manual and some videos https://www.google.com/search?q=Jayco+Prestige+operate+front+blinds ..
4/23/2022 12:15:31 AM • Jayco 2013 Jay... • Answered on Apr 23, 2022
Jayco wall mount air conditioner
Contact your local service center directly or online here:
2/6/2018 2:20:35 AM • Jayco 2013 Jay... • Answered on Feb 06, 2018
Every time i put a 15amp fuse in it blows it whats wrong
You will have to find the short circuit some place in the wiring. The first thing to do is trace the circuit to find the short. You have to locate the item that the circuit controls and determine if that is where the short is. Disconnect what ever it powers and see if the fuse still blows if it does now blow with that item disconnected you have found the problem. If it still blows it is in the wiring some place.
11/8/2014 5:52:45 AM • Jayco 2013 Jay... • Answered on Nov 08, 2014
Any one have a wiring diagram for the holding tanks. the wires for the grey and black water are all broken off
Usually white will be the ground going to the lowest and usually a little more distance from others. Then simply get someone to push levels button on monitor and as you touch each wire separately to white wire or screw head it is attached to, the corresponding light at panel will tell you which is which.
9/3/2014 7:22:45 AM • Jayco 2013 Jay... • Answered on Sep 03, 2014
I need a wiring diagram?
goto jayco.com and enter your model number to d/l a manual for it. also you need too goto wemakeitsafer.com there a a few recalls regarding the wiring on your model and other jaycos. seems they wire things with thee wrong polarity
6/21/2014 11:56:38 PM • Jayco 2013 Jay... • Answered on Jun 21, 2014
Does any one have a wiring diagram?
goto jayco.com/tools/archives. enter model number and you can d/l a pdf of manual. the wiring is probably backwards. deepending on what you are having a problem with. also goto wemakeitsafer.com that website shows all the recalls for this particular model. there are a few regarding wiring.
6/21/2014 11:54:13 PM • Jayco 2013 Jay... • Answered on Jun 21, 2014
3answers
Electronic ignition hot water heater (6gal) lights but wont get water hot. The red light inside my RV goes off and back on after about 3 minutes. When I checked the unit outside, the pilot is lt, but
check to see if setiment has settled on the pilot....blow it out with air if it has. This issue comes up often with water heaters and rv refers. If that is not the problem and the pilot remains lit, but never increases when the thermostat is turned up, you probably need a new gas valve/thermostat.
7/13/2019 4:07:16 PM • Jayco RVs • Answered on Jul 13, 2019
ANYONE KNOW WHAT DIAMETER CABLE IS FOR LIFT CABLES ON A 1993 Hi-Lo MOD 2693 B CAMPER? THANKS
Question edited for clarity and spelling 'diameter'. Question moved from Cars and Trucks to RVs. Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Help in the link plus videos. https://www.google.com/search?q=1993+HI+LO++MOD+2693+B+CAMPER+replacement+cables ..
4/12/2024 3:56:16 PM • RVs • Answered on Apr 12, 2024
Have a Norcold model 482 RV fridge for my Georgie boy impulse and has stopped working on electric and propane. metal sleeve above pilot light from outside access panel gets to hot to touch.
I'd check the control board. You MUST have good 12v going to the board in order for it to function correctly. Sounds like you have decent propane if the burner assembly gets hot. The key to the whole thing for either propane or 120v usage is good 12v.
4/8/2024 5:24:28 PM • RVs • Answered on Apr 08, 2024
Locating the water heater bypass on forest river 398
Locating the water heater bypass on a Forest River RV, specifically the Forest River Georgetown 398 model, can vary based on the specific layout and design of the RV. However, in most RVs, including Forest River models, the water heater bypass valves are typically located near the water heater unit itself. Here are some general steps to help you locate the water heater bypass on your Forest River Georgetown 398: 1. **Identify the Water Heater Unit:** - The water heater in your RV is usually located inside a cabinet or compartment, either inside the RV or accessible from the exterior. - It is commonly found in the kitchen area, bathroom, or an exterior compartment. 2. **Access the Water Heater Compartment:** - Locate the compartment where the water heater is installed. This could be inside the RV or in an exterior storage compartment. - Open the compartment door to access the water heater. 3. **Look for the Bypass Valves:** - Once you have located the water heater, look for the bypass valves near the water heater unit. - The bypass valves are used to redirect water flow during winterization or maintenance to bypass the water heater. 4. **Check Behind the Water Heater:** - In some cases, the bypass valves may be located behind or on the backside of the water heater unit. - You may need to remove a panel or access door to reach the bypass valves. 5. **Identify the Bypass Valve Configuration:** - The water heater bypass system typically consists of three valves: a cold water valve, a hot water valve, and a bypass valve. - The bypass valve should be set to bypass the water heater when winterizing the RV or performing maintenance. 6. **Consult the RV Manual:** - if you have one, refer to the owner's manual or documentation provided with your Forest River Georgetown 398 for specific information on the location and operation of the water heater bypass system. If you are unable to locate the water heater bypass valves or have difficulty accessing them, it may be helpful to consult with a Forest River dealer or RV service center for assistance.
3/22/2024 2:50:42 AM • RVs • Answered on Mar 22, 2024
I have a 2013 coachman my truma cp25 is saying operation fault connection error can u help please
The Truma CP25 is a digital control panel used for operating the Truma Combi heating and hot water system in RVs, including Coachmen RVs. If you are encountering an "Operation Fault - Connection Error" message on the Truma CP25 panel, it indicates that there is an issue with the connection between the control panel and the Truma Combi unit. Here are some steps you can take to troubleshoot and potentially resolve this error: 1. Check Power Supply: - Ensure that the RV is receiving power and that there are no electrical issues affecting the Truma Combi unit. - Verify that all power connections to the Truma Combi unit and control panel are secure and not loose. 2. Reset the System: - Try resetting the Truma Combi system by turning off the power to the unit for a few minutes and then turning it back on. This may help reset the connection error. 3. Inspect Connections: - Check the wiring connections between the Truma Combi unit and the control panel. Make sure the connections are secure and there are no loose or damaged wires. - Clean the connection points to ensure there is no corrosion or debris affecting the connection. 4. Update Software: - If possible, check if there are any software updates available for the Truma CP25 control panel. Updating the software may resolve any compatibility issues causing the connection error. 5. Contact Truma Support: Good luck
3/22/2024 2:47:37 AM • RVs • Answered on Mar 22, 2024
2answers
2012 High Country Cougar 321RES Converter.
Fortunately the company is still in business for you can get a manual. As I understand it, there is a way to switch to switch between trailer battery power, mains hook up, or tow vehicle power for charging. https://www.google.com/search?q=2012+High+Country+Cougar+321RES+manual ..
3/17/2024 4:32:26 AM • RVs • Answered on Mar 17, 2024
I have a 97 jayco 36ft eagle designer. All of my ext lights stopped working. I have power at truck side 7 pin. Is there a main fuse for the cable going into trailer from 7 pin?
Check the grounds on the lights and there is somewhere on the trailer where they are all grounded to the chassis. This is often corroded. https://www.google.com/search?q=1997+jayco+36ft+eagle+designer+no+exterior+lights ..
2/13/2024 4:41:06 AM • RVs • Answered on Feb 13, 2024
1994 Sun-Lite truck camper. Looking for a Manual for it please?
Question edited for clarity. Question moved from Cars and Trucks category. Help in the links, but no manual. There are RV Forums for Sun-Lite. https://www.google.com/search?q=1994+Sun+Lite+truck+camper+manual https://www.google.com/search?q=1994+Sun+Lite+truck+camper ..
1/28/2024 7:36:39 PM • RVs • Answered on Jan 28, 2024
How to replace a Converter on a 2007 coachman freelander 2230rk
To replace the converter on a 2007 Coachman Freelander 2230RK, follow these steps:
  1. Safety First: Disconnect the RV from the power source and ensure all appliances are turned off.
  2. Locate the Converter: Typically found near the electrical panel, the converter is responsible for converting AC to DC power.
  3. Disconnect Power: Turn off the main breaker and disconnect the RV battery.
  4. Remove Old Converter: Carefully disconnect wires from the old converter. Note the connections or take a photo for reference.
  5. Install New Converter: Connect wires to the new converter following the reference or photo. Ensure a secure and proper connection.
  6. Reconnect Battery: Reconnect the RV battery and turn on the main breaker.
  7. Test the System: Verify that the new converter is functioning correctly by checking appliances and lights.
Remember, if you're not comfortable with electrical work, it's advisable to seek professional assistance. For more info: Medical Imaging Specialists in Texas
12/21/2023 2:40:45 PM • RVs • Answered on Dec 21, 2023
Manual for 2000 forest river cardinal 32lx
As of my last knowledge update in January 2022, specific documents, such as owner's manuals for RVs, may not be readily available online for older models. However, you can try the following options to obtain a manual for your 2000 Forest River Cardinal 32LX: 1. **Manufacturer's Website:** Visit the Forest River official website and check their support or customer service section. Some manufacturers provide online access to owner's manuals or offer support services to help you obtain one. 2. **Forest River Customer Support:** Contact Forest River directly through their customer support or service department. They may be able to provide you with information on how to obtain a manual for your specific RV model. 3. **RV Owner's Forums:** Join online RV owner's forums or communities where fellow RV owners discuss their experiences. Members often share resources and may have digital copies of manuals for older RV models. 4. **Used RV Dealerships:** Reach out to used RV dealerships, especially those that specialize in older models. They may have access to or be able to point you in the right direction for obtaining manuals. 5. **RV Owner's Clubs:** Check if there are RV owner's clubs or associations dedicated to Forest River owners. Members of these clubs might have valuable resources or copies of manuals for your specific model. 6. **Online Marketplaces:** Explore online marketplaces, auction websites, or forums where RV-related documents are sometimes sold or shared. 7. **Libraries and RV Shows:** Local libraries may have RV-related resources, and attending RV shows or events might connect you with knowledgeable individuals who can assist. Remember that the availability of manuals for older RV models can vary, and it may take some effort to locate one. If you're unable to find a physical manual, consider reaching out to Forest River directly for guidance or assistance. Additionally, some RV owners may have scanned or digitized versions of manuals, so online communities and forums can be valuable resources in your search.
11/19/2023 9:06:14 PM • RVs • Answered on Nov 19, 2023
2answers
Looking for a owners manual for a 1999 gulfstream Yellowstone rv
Contact your local authorized Gulf Stream retailer or contact them directly here: Contact Us
11/8/2023 5:13:20 PM • RVs • Answered on Nov 08, 2023
Jayco 2013 Jay Flight Swift SLX 154BH Logo
8 questions posted
Top Jayco RVs Experts
Renee Knafel-Bullock
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Jayco RVs Expert? Answer questions, earn points and help others
View Most Popular
Jay Flight Swift SLX 154BH Jayco
  • Jay Flight Swift SLX 154BH Jayco
Most Popular Question
large front blind work jayco prestige
  • RVs
