20 Most Recent
Blue Coat Systems ProxySG SG210-5 Proxy Edition Security Appliance Questions & Answers
Forgot my applient sg210.4
there is a reset button located on the back of the appliance that can used to reset the appliance back to factory defaults
8/18/2011 1:14:35 PM •
Blue Coat...
Answered
on Aug 18, 2011
Changhong Ruba 58? 4K UHD Smart LED TV (U58H7i) showing horizontal purple and blue lines. How to fix please?
I believe you can troubleshoot by following steps below:
- Check the source: Make sure that the issue is not with the source device, such as a cable box or gaming console. Try connecting a different source device to the TV to see if the issue persists.
- Check the signal strength: Weak signals can cause picture quality issues. Check the signal strength of your cable or antenna connection. If it's weak, you may need to reposition your antenna or contact your cable provider.
- Check the cables: Inspect the cables for any damage or loose connections. If you find any issues, replace the cable or reconnect it properly.
- Check the T-con board: The T-con board is responsible for driving the pixels on the screen. If the board is faulty, it can cause horizontal lines. Check the T-con board for any visible damage or burn marks. If you find any issues, you may need to replace the board.
- Check the ribbon cables: Ribbon cables connect the T-con board to the LCD panel. If these cables are loose or damaged, it can cause horizontal lines. Check the ribbon cables for any visible issues and reconnect them properly Check the LCD panel: If none of the above steps work, the issue may be with the LCD panel itself. A faulty panel can cause horizontal lines. In this case, you may need to replace the panel or contact a professional repair service.
Note: Opening the TV can be dangerous and may void your warranty. If you are not comfortable with opening the TV or performing these steps, it's best to contact a professional repair service.
Vostro 1510 num lock and other blue lights blinking and on
It sounds like there may be an issue with the keyboard or the BIOS settings on your Vostro 1510 laptop. The fact that the num lock and other blue lights are blinking and on suggests that there may be a problem with the keyboard or with the settings in the BIOS.
Here are a few steps you can try to fix the problem:
- Check the keyboard: Make sure that the keyboard is properly connected and that there are no stuck keys. Try to clean the keyboard, if it is dirty.
- Check the BIOS settings: Enter the BIOS settings by pressing the F2 key during the boot process. Look for an option to disable the num lock or other blue lights.
- Check the software: Check if there are any software updates available for the keyboard driver and BIOS on your laptop.
- Check the power management settings: Make sure that the power management settings are set to turn off the keyboard backlight after a certain amount of time.
- If the problem persists, it's best to contact Dell customer service or a professional computer technician for further assistance.
It's important to note that working with a computer's BIOS can be dangerous, if you're not comfortable working with BIOS, it's best to get it serviced by a professional.
I have a h p pavillion 15 notebook pc it powers on and goes to blue screen help it will not do anyting
Your laptop most likely has a corrupt file that windows needs in order to run properly.
You did not state which operating system is on the laptop so it's hard to be specific. In any case, hit the F8 key as the laptop is booting until you come to the boot selections.
From their you can boot into safe mode and see if that works. In some cases, this is all you need to do in order to reboot into normal Windows. If you see a "boot last known good configuration" boot into that instead of safe mode.
If you cannot boot into last known good configuration or safe mode, you will need to insert your windows repair disk or your Windows Installation disk and run the repair tool.
