20 Most Recent Kenmore 22622 Top Load Washer Questions & Answers
Oil drip on bottom of gearcase Kenmore Model 110.21882 washer
Unless there is an abundance of oil this is normal.
If you tilted the machine to replace the coupling that could cause some oil to escape also.
There is a small hole in the top cover of the gearcase to release pressure. Sometimes a little oil comes out too.
7/1/2022 8:35:38 PM • Kenmore 22622... • Answered on Jul 01, 2022
My washing machine (Kenmore 70 Series) does not spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
5/2/2019 5:38:31 AM • Kenmore 22622... • Answered on May 02, 2019
Need part diagram for Malber P28 washer
Where can you purchase a knob for the cycle for a P28 Malbec washing machine.
7/3/2018 1:31:55 PM • Kenmore 22622... • Answered on Jul 03, 2018
0answers
Help! I replaced the clutch and motor coupling a
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
9/21/2017 3:31:53 PM • Kenmore 22622... • Answered on Sep 21, 2017
Kenmore 11092587210
Replace the lid switch... they tend to crack and when you are adding pressure to the lid you are closing the gap...you wont be able to get away with pushing down on the lid for long...
3/9/2014 3:18:48 AM • Kenmore 22622... • Answered on Mar 09, 2014
0answers
Kenmore 110 22622 100 I have the motor sitting on
the magnets or the stator are going in the motor. I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
8/24/2013 5:54:24 AM • Kenmore 22622... • Answered on Aug 24, 2013
2answers
I put in a load. The machine filled up but did not
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
8/2/2012 10:32:53 AM • Kenmore 22622... • Answered on Aug 02, 2012
Kenmore 22622 Top Load Washer Logo
140 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
kenmore 110 22622 100 motor sitting
  • Washing Machines
