20 Most Recent
Avent Philips iQ Bottle Warmer without Bottle Questions & Answers
I need directions on how to use my philips avent
Keep power button depressed for 3 seconds
Press power button to select condition of food/milk (room temperature, refrigerated, or frozen - buttons are listed from right to left)
Press selector button (on right) to select the amount of food, single press to increase the food amt in increment of oz
Keep selector button depressed for 3 seconds to get it started
HOW TO DE SCALE THE Philips AVENT Digital Bottle
Mix one sachet of citric acid* (10g) with 200ml/7oz of water. Pour solution into the
empty warmer. DO NOT place a bottle, jar or cup into the warmer when de-scaling.
Close the lid of the warmer and programme the warmer to run with 310ml/11oz of
milk from frozen. After the warming cycle has ended, leave the solution to cool for
30 minutes before emptying the warmer and rinsing with tap water. Wipe the inside
and outside of the warmer with a damp cloth only.
OR:
Pour 100ml/3.5oz of vinegar mixed with 200ml/7oz of cold water into the warmer.
Allow liquid to stand in the unit until any limescale has dissolved. DO NOT place a
bottle, jar or cup into the warmer when de-scaling. DO NOT start the warming cycle.
Empty the unit and rinse thoroughly. Wipe the inside and outside of the warmer with
a damp cloth only.
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
My Pal Scout needs replacement battery spring..
I would perform a test use of the spring before purchasing it to reach this conclusion. You can call ahead to several part stores that you've identified to carry the spring and request if test use is possible. Then, work with the stores that say "yes". Thank you.
9/30/2022 5:41:42 PM •
Baby Care
Answered
on Sep 30, 2022
Tomy baby monitor srv 400 instruction
Hi
I have Tomy srv 400 but the parent unit is not working. I have attached a photo to show what its giving me when plugged.
If anyone knows how to fix it.
Thank you
4/1/2019 11:49:08 PM •
Baby Care
Answered
on Apr 01, 2019
I feel REALLY down, I Am Never Going To Get A Baby Girl?
Other
people would say, it does not matter what gender your baby will be and
that is a natural reaction but to some, this is a serious concern. Stop
worrying, Gender Selection Clinic
is the solution to your problem if you are really serious about it.
Technology and science have made it possible for people to get pregnant
and to choose the gender of their kids. The embryo gender selection IVF
is being performed by medical doctors around the world. This system has
been proven for decades. The success rate of having a girl is 93%. This
method though is a bit expensive but if you really want it, then the
cost would not be a problem to you. Both you and your husband must have
an open mind on this. Otherwise, it will create misunderstanding between
the two of you.
8/15/2018 7:03:40 AM •
Baby Care
Answered
on Aug 15, 2018
Is it dangerous to wear the wrong size of nursing bras?
Usually a woman's breasts engorge very quickly after giving birth and take a few weeks to gain a stable size, usually one size bigger than what she had before giving birth.Because of the quick and unpredictable extent of ****** growth some women end up wearing the wrong bra size, and while wearing a bigger size may just turn out to be uncomfortable, wearing a smaller bra size while breastfeeding may reduce their milk supply and cause a painful infections called mastitis.
4/3/2018 2:57:56 AM •
Baby Care
Answered
on Apr 03, 2018
How do they work
The basic loop is simple:
Feed
Burp
Change diaper
Get to sleep
Repeat
Then you need to work in a "change clothes" subroutine, which runs once/day, or when the outfit is filthy.
But while that loop is running, you need to frequently:
Maintain eye contact
Smile
Talk (content not important; babies hear high pitches better)
Play (Peek-a-boo works with a wide range of ages, but basically any repetitive action delivered with a smile will amuse a baby)
And snuggling. Lots and lots of snuggling.
10/22/2017 2:46:29 PM •
Baby Care
Answered
on Oct 22, 2017
