20 Most Recent
Zonet ZSR1134WE Wireless Router Questions & Answers
I forgot my wpa key..and
1. when the
unit is powered on, hold down its reset button for 30 seconds
2.
while still holding down the reset button, unplug the router from
power and hold for an additional 30 seconds
3.
still holding down the reset button, turn on power to the router
again and hold for 30 more seconds
After this
process (a total of 90 seconds) is complete, your router should be
restored to itsfactory default state.
From your browser, access the setup page at http://192.168.1.1
Login as admin with password guest
How to reset password
Look on the side and bottom of the router and see if there is an ip
address that you would put into your internet browser to get into the
router. It will be something like 192.168.1.1Once you get into
the router you will need to enter the user id and password then go to
the Wireless Security Tab and change or enter the password.If
you don't know the ip address then search your manual. If you don't
have the manual go to the manufacturer's website and view or download
it.
Get
online
and got to www.google.com In the google search box type: "Zonet
Support" (without the quotes and put your manufacturer name before
Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals. The manual will tell you the
ip address and it will give you the default user id and password to get
into the router.
The router fails to connect to the internet. All
First try to hard reset the router. there is a button on the back of it.
If your router is hooked to a modem you might need to call your provider and have them reset the mac address on the modem.
I need a zonet default
Hello aclark447, I believe that the default IP address is "192.168.1.1", however if for some reason that doesn't work try running your command prompt (Windows key + r, type in cmd), and typing in IPCONFIG. If you are connected to it, it should be the default gateway. The default username and password for your device is user:guest - pw:guest. Hopefully this will fix your problem, please have a great weekend!
I can not get to
There should be a reset button on the back of the unit. Depress and hold for 30 seconds should reset it back to factory default.
I went to my uncles
You'll have to remove the network from your sharing centre and manually add it again. You should be able to find the code on the bottom of the router.
Default pin does not work
Are you pressing the button long enough? Most, if not all, reset to default buttons on appliances like this require you to hold the button down for 5 seconds or more before it will reset. Watch the lights on the front of the router while you hold the button down. They should start flashing after about 5 seconds, then release the button. The router will reboot to default configuration. The flashing lights mean that the router erased it's startup config and it is now at it's default configuration.
I just purchased a zonet ZSR1134WE wireless router
or those unsure of how to connect your Wii to the internet wirelessly using a wireless router, here is my step-by-step guide for getting online.
First you'll need a compatible wireless router that can be found by going to the following site: http://www.nintendowifi.com/
From there, select your country, which will then take you to the WiFi index page. On this page, mouse over TECH SUPPORT at the top and from the menu that drops down, click on ROUTER INFO. Near the top of the following page, under the words "I don't own a wireless router, help me find one!" there is a "click here" link, which will finally take you to Nintendo's wireless router rating page, which you can look through to either see if your router will work or if you don't have a router, which one to get. For reference, if you live in North America, here is the router rating page.
The following are pics I took of my TV when first setting up my Wii's internet connection...
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
