20 Most Recent
Zyxel NBG-417N Wireless Router Questions & Answers
I have connection between my
dchp problem. sounds like the modem is doing dhcp that's why it works plug in directly. disable the dhcp server in the router go to Network > DHCP Server > General in the router and disable it. only the modem or router can do dhcp.
How to change username/password ?
First you have to connect to it with a cable CAT5 is the standard cable. Looks like big phone cord. Then you have to know what the router address is. This can be done using a DOS prompt and you type IPCONFIG /ALL and hit enter. IT will show up as default gateway. IT is going to be something like 10.0.0.1 or 192.168.1.0 Then you go to an internet browser and you type in that number where you usually put a website name. You hit enter or click go and it should bring you to the router logon page. You can then logon with the old information and then use the menu to change pages to change the logon info. If the router came with a CD you should use that because it is easier.
Hi. i have the zyxel
you need to check if you have the wirelees hot spot enabled
do it following the next steps
1- Press the WPS button on the nbg-417n, you should see that the wlan led blinks
2- Check that your wirelees adapter is enabled in your lap
then it should connect to the net
if you still have issues check the next document
http://www.zyxel.co.uk/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420081028103616
Scheduling not working
If you have configured the router correctly, surely it is a firmware issue. Other than that make sure the router is on standby mode with power.
I donot remambar password
Most default user credentials are - admin/admin.If you are unable to log in, then most routers come with a reset key. For Zyxel NGB-417N router, press the reset key with a pin. hold on the pin till the device reboots.Login with the default user id and password and setup the router.
Router not turning on
It may be the AC jack has been damaged due to pulling on the power cable, wiggle the plug while in the device. Try to reset the device to default settings. After a firmware update the setup CD may not work, go online to reconfigure.
