20 Most Recent
Belkin F5D7234-4 Router Questions & Answers
How can i connect my
Your PSP does not support the WPS feature on the Belkin router. The solution is to turn WPS off. WPS can be disabled in the configuration program for your router.
You do not need WPS it is simply a protocol to make conection to some modern devices simpler.
I need to open my
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Wireless light flashes red when my laptop tries to
if your using lenovo and is an Ideapad Y series or a G series Laptop look for the program called lenovo readycom in the control panel add remove programs if you have XP and if vista go to control panel and look for programs and features this goes the same with win7 just uninstall Lenovo Readycom 4.0 or 5.0 and as well look for a program called network magic if that program is present then uninstall this as well then restart your laptop, try connecting again ^_^ happy surfing ..
I just got the Belkin
Here is a link to Teleblend tech support.
http://support.teleblend.com/index.php?_m=downloads&_a=view&parentcategoryid=1
With my VOIP setup @ home, my path is as follows:
Modem -> VOIP Adaptor - phone
Ethernet out - router Wan input
How to disable MAC filtering
MAC (Multimedia Access Control) addresses are unique sets of codes assigned to electronic devices that identify the devices on a network. MAC filters work by either allowing or denying only specific MAC addresses. MAC filters are a great security measure; however, if your network needs to be open to public or guests, or you're adding and removing devices often, then you should consider turning off MAC filtering.
EditMethod One of Three:
Wireless Routers (Windows)
Open the Command Prompt. You can access it from the Start menu, or by pressing ? Win+R and typing cmd.
Type .ipconfig and press? Enter.
Find your active network connection.There may be several connections listed in the readout, and you may have to scroll up to find your active connection.
Look for the .Default Gatewayentry. This is the address for your router. Write it down.
5
Open a web browser. You can access your router's configuration page from any web browser as long as your computer is connected to the network.
6
Enter the .Default Gateway address into the browser's address bar.
7
Log in with your admin account.Routers are protected with an admin login and password. Check your router's documentation or look up the model online to find the default login information.
- If you can't figure out how to log in to your router, you can reset it by pressing and holding the Reset button on the back for about 30 seconds. After the router restarts, you will be able to log in with the default admin information.
- Most default logins use "admin" as the username, and then "admin", "password", or a blank field as the password.
8
Open the "Advanced" section and look for "MAC Filtering", "Access Control", or something similar. Actually defining where the "MAC Filtering" section is located is very difficult, as the location and labeling is different for every router. Generally, you can find the "MAC Filtering" or "Access Control" settings in the "Advanced" section, though it may also be found in the "Security" or "Wireless Settings" sections.
- Not all routers use MAC address filtering. Some router's limit access based on static IP addresses assigned to each device.
9
Disable MAC filtering. Again, the wording and location will vary depending on the router, but you will generally be able to select a "Disable" option to turn off MAC filtering.
- This may be a checkbox, a button or a selection that you can make.
10
Save your changes. Click the "Apply" or "Save" button to save your changes to the router settings. Your router will apply the changes, which may take a few moments.
- If you are configuring your router over a wireless connection, you may be logged out when settings changes are saved.
How do you set a passwood so nobody get in
You need to encrypt your wireless router to protect your Internet access fro unauthorized access. Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1 The default PW = blank (just press Enter) You can now change the default admin password. You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
