20 Most Recent
Dell Vostro 1400 / Inspiron 1420 - 24X CDRW/DVD Combo Drive Burner Questions & Answers
Cd drive cannot read or respond
Unfortunatly it is likely a bad drive, a loose internal connection, or a dieing motherboard. Go to dell.com and ensure that all your chipset drivers are up to date, if that doesn't fix it you will likely have to either RMA or, if it is out of warranty, take it to a repair shop.
At boot up , my
It may be due to the loose contact of the cables connected to the drive, if the tray ejects that means it receives power, tightining the cables should resolve the issue
Does not recognise any disc
Hello gavin50
This is a relatively common problem with all dvd players. The problem
is that either the lens has become dirty or the lens has burnt out.
If the lens is dirty , you have two relatively easy options to fix this.
The first option is to go to your local music/electronics store and ask
them for a cd/dvd lens cleaner kit. This kit consist of a CD with one
or two little brushes on it , and a lens cleaning solution.
You simply put a drop of solution on each of the brushes and then
insert the cd/dvd in the dvd player. Play this disc for about 5 min and
then try one of your normal disks. Repeat a few times if this does not
solve your problem immediately.
Open your drive and power off your laptop.Then locate the lens in the tray of the drive.
Borrow some nail varnish REMOVER (not varnish,
believe me , someone has made that mistake before) and put a drop on a
cotton ear tip.
Gently in a circular motion clean the lens. Do not press against the
lens , just balance the cotton ear tip on the lens with your fingers.
Now take another cotton tip and pull on the cotton to loosen it up a
bit. Gently dry the lens in the same manner as you did the cleaning.
Make sure no pieces of cotton got stuck near the lens after drying.
Then try your drive again.
If you followed either one or both of these steps and the unit will still not
read a disc , the lens has blown and will have to be replaced.
Depending on your unit , this will cost about half of the cost of a new
player if it is available on the market so I would suggest you replace the unit all together.
I hope this information is helpful to you and please feel free to contact me if you need more information.
Kind Regards
Stephan
Dell Vostro 1400 green stripes problem
Hi ravi_kuma108 i have the same problem you described in a similar laptop. did you find a solution or clue about it? I only can guess its a bottom flex-cable connector or top flex-cable connector problem. If you had something you can share i will be apreciated.
My vostro 1400 laptop does not detect the battery
hi, gmotian:i think the battery does't match your laptop,i suggest you buy a new one battery from http://www.adapterlist.com/dell. which is an online shop,exporting various models replacement laptop battery.best luck!
My laptop monitor keeps on freezing, turning
Go to www.dell.com and download all of the drivers for your laptop and install them.
I think this is the right page according to your request:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=dhs&catid=&impid=&os=WW1&osl=en&SystemID=INS_PNT_PM_1420
Once you have the latest factory drivers, everything should work. If not, you may have other issues. Let me know!
Good Luck
Peter
My laptop is Dell Vostro 1400, 18 months old. i am
Seems like graphics card problem.
It may be that the card needs to be reseated (don't do it yourself if you have not done it before).
If it is a software problem, then following procedure may correct it.
Restart the computer and right after tap F8 key continuously.
You will see advanced boot menu.
Use up/down key on keyboard and select Last Known Good Configuration and hit enter
It should boot you up.
If that does not work, do the above procedure and instead of Last known select "Safe mode" from the list. Log into your account and click "No", it will show you system restore window, You can try to restore the computer to an earlier date when it was working fine.
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
