20 Most Recent Acer Veriton M661 PC Desktop Questions & Answers
Warning your chassis has been opened
normally you have to setup bios not check chasis open. or you have to cut circuit sw for chassis check. good luck my friend.
1/22/2015 12:21:25 PM • Acer Veriton... • Answered on Jan 22, 2015
What pci communications controller acer m661 drivers
if you have problem with installed driver. you can use driver pack solution to find any driver on your computer. it easy to results your problem. good luck my friend. this mian board support windows xp & vista you can download all drivers for m661 from this link below. http://www.acer.co.th/ac/th/th/content/drivers
1/22/2015 3:31:20 AM • Acer Veriton... • Answered on Jan 22, 2015
2answers
Power indicator light is on but will not run, fan turns off and on randomly
It sounds like the power supply in your computer has gone bad. Thats the box you plug the power cable into in the back of the computer. It looks like you should be able to get a standard ATX power supply and replace it.. or have someone do it for you. You can get one for no more than $50, sometimes less.
1/8/2015 1:15:16 AM • Acer Veriton... • Answered on Jan 08, 2015
4answers
Your chassis has been opened. Press F1 to continue
hi press f1then go to pc health on bios, chassi option press enter key .choos e reset the press f10 save yes
12/7/2014 5:58:22 AM • Acer Veriton... • Answered on Dec 07, 2014
I have a pc lab with 20 pc ,mor than half of them
Usually this happens due to either virus or network misconfiguration.Ensure that all systems are running free of virus.First close down all systems and remove them from network. Began scanning each system. The problem when many computers are running in network is that if one system is having problem it can effect other systems too.
9/26/2013 8:28:20 AM • Acer Veriton... • Answered on Sep 26, 2013
0answers
I would suspect a PSU, how old is the machine? Check the CMOS battery, reseat the Memory mods.
12/25/2012 6:42:10 PM • Acer Veriton... • Answered on Dec 25, 2012
What type of motherboard do I need for a acer veriton m661
you need m.b intel Q35/31 / G41 intel chipset mini m.b
  • dimention aroundHeight: 14.4"
  • Width: 7.1"
  • Depth: 17.4"if use the same case
  • 12/4/2012 2:07:03 PM • Acer Veriton... • Answered on Dec 04, 2012
    Q9550 With Acer EQ35M MOBO
    It is very likely that you simply do not have the right BIOS setup for the new processor. You will likely have to flash all your bios to get the new processor to both be recognized and to be able to recognize components on the motherboard. That is quite a jump in technology and it may be that the motherboard simply will not support the new processor period. In that case, be VERY careful buying your new board and make sure it specifically supports your processor. Sorry I could not be more help!
    5/22/2012 5:40:46 PM • Acer Veriton... • Answered on May 22, 2012
    What does a video card do?
    The video card sends video data to the monitor. If the monitor does not display any images then the video card could be faulty.It could also mean the monitor is faulty.To check whether the video card or monitor is faulty, connect another monitor to your computer, if this monitor also does not displays any image then the video card is faulty.
    4/30/2012 7:27:25 AM • Acer Veriton... • Answered on Apr 30, 2012
    Bought the computer in 2008, still has never
    It can't be the cord, that's for sure. It wouldn't power on at all with a faulty cord. It can be either the power supply or the motherboard. I assume you don't have another power supply to replace the current one, so the only thing you can do to test it is to remove as many devices possible from the power supply and see if it is starting. You can remove any CD/DVD device, floppy and HDD. Just remove the power cord that comes from the power supply into the device. Sometimes the power supply does not have enough wattage power for all the devices hance it fails to start. If it powers up then you know for sure it's the power supply not having enough wattage. If it's doing the same thing still your cheaper option would be to replace the power supply with a more powerfull one and if it's still doing the same bit will isolate the problem to the motherboard which if it's faulty you will probably have to replace pretty much the whole system because new motherboards need new RAM DIMMs and maybe new graphic card.
    As for the power button, if you open the case you can check if the cables are connecter properly, the PIN marked with PWR (could be something different but similar saying that it is the front button) should have the cable marked the same connected to it.
    12/5/2010 11:54:00 PM • Acer Veriton... • Answered on Dec 05, 2010
    go to the bios and disable this warning
    11/4/2010 2:59:30 AM • Acer Veriton... • Answered on Nov 04, 2010
    2answers
    My acer veriton m661 desktop--i cannot set the
    Examine the setup options to see if there's a failsafe mode or a BIOS reset/restore. Otherwise contact Acer tech support to see if they can provide a BIOS reset. You may have to send it to them. Older motherboards had BIOS on a 28-pin socketed chip called an EPROM. These could be ordered from various suppliers with upgrades, etc. I have not seen these in use lately.
    12/13/2009 9:09:03 AM • Acer Veriton... • Answered on Dec 13, 2009
    2answers
    Cant find pci serial port for acer m661
    Please see illustration below, hope this helps.
    11/25/2009 1:50:21 PM • Acer Veriton... • Answered on Nov 25, 2009
    3answers
    Hi need help asap.
    I opened my acer desk top box to clean dust out and now has warning chassis open.
    I cant access the bios or anything else. Does someone have a suggestion????
    Panicking
    2/14/2021 11:08:02 AM • Acer Veriton... • Answered on Feb 14, 2021
    Acer Veriton M661  PC Desktop Logo
    27 questions posted
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
    View Most Popular
    Veriton Acer
    • Veriton Acer
    Most Popular Question
    chassis opened press f1 continue
    • Computers & Internet
