20 Most Recent Acer Veriton M420 PC Desktop Questions & Answers
Not turn on
Unplug all power cables and check for bad connections. Reconnect all cables. Does the power supply fan rotate? Yes or No? Looking through the vented left side of the tower with the power cable plugged in do you see an LED lit? If no fan spinning in the power supply and no LED lit, then I suggest you change the power supply. Either do it yourself (very easy to do or have a tech shop do it for you - it's cheaper to do it yourself). 1. Un-plug all power cables. 2. Unscrew side panels. 3. Count how many of each type of power cable is required for on board devices. 4. Calculate power requirements by watts. 5. Purchase new power supply that has the cables you require and the required wattage to support your devices. 6. Unplug all power cables inside. 7. Plug in new power supply. 8. Plug in power cable first before turning on the computer. The green LED on the motherboard should come on. Congrats you have power. 9. Turn on the computer. 10. Enjoy!
11/25/2015 10:24:44 PM • Acer Veriton... • Answered on Nov 25, 2015
Why IE 8 not installed
6/18/2013 8:38:54 PM • Acer Veriton... • Answered on Jun 18, 2013
Install hp deskjet 4213
normallay the hp deskjet coming with CD for set-up and follow the steps.2) if you do not have the disk, go to www.hp.com give your model, etc and download the software for installing the hp desket 4213God bless you
6/11/2013 12:36:07 PM • Acer Veriton... • Answered on Jun 11, 2013
Fitting an external PCI graphics card ... issues.
Go into the device manager find the card you do not want to use then disable it do not delete it. Restart the computer making sure that your display is plugged in you want to use and it should show up. The way your doing it is allowing both monitors to or both drivers are active. John
4/18/2012 11:09:04 AM • Acer Veriton... • Answered on Apr 18, 2012
During running operitng system my
First you re-install the chipset driver. If same issue showing, change the VGA cable. If problem remains, connect your system with other working monitor (if it is working, it'll be the problem with the monitor). Again problem showing, it should be the problem with the chipset. Take the motherboard to a chip level service centre...
Good Luck
8/2/2011 6:39:05 AM • Acer Veriton... • Answered on Aug 02, 2011
Blue power led doesn't come on when powering
Try reseating the ram modules, and the video card if you have an external one. To do this, open the case and locate the ram, they're long green sticks with black squares on them, to remove them, depress the taps on both sides and reseat them in their port. Then look for where your monitor plugs in, if its a removable card, try removing it and inspecting it for obvious damage, replace it and see if the machine boots. If possible, try swapping the video card with another one from a working computer to narrow down the problem.
5/3/2011 3:08:22 PM • Acer Veriton... • Answered on May 03, 2011
3answers
Warning your chassis has been opened
Hi need help asap.
I opened my acer desk top box to clean dust out and now has warning chassis open.
I cant access the bios or anything else. Does someone have a suggestion????
Panicking
2/14/2021 11:08:02 AM • Acer Veriton... • Answered on Feb 14, 2021
Acer Veriton m264 wont start
check all fans are working and that its not over heating
3/29/2015 1:36:18 AM • Acer Veriton... • Answered on Mar 29, 2015
Why does the belkin guest access page appear? Have had PC for over 2 years and last week this page started to appear for the first time.
There is an option in your router to disable that option. You have to get into the settings for the router you have. Typically you can open up a web browser and type 192.168.2.1 and it should give you a log in window. If you have not set an admin password for the router just leave it blank and hit ok. Look on the left column to find "guest access". Click on that and you will see the option to click disable. Hope this helps
2/14/2015 10:09:41 PM • Acer Veriton... • Answered on Feb 14, 2015
Starting problam
format your os
1/28/2015 1:32:55 PM • Acer Veriton... • Answered on Jan 28, 2015
2answers
How do i install an ssd to replace hard drive
The drives will usually come with a utility to copy your old drive to the SSD and make the SSD the bootable drive. You just need to have both drives connected at the same time. Check for download instructions in the packaging with the drive or check the manufacturers website.
1/7/2015 11:09:52 PM • Acer Veriton... • Answered on Jan 07, 2015
Desktop wont start up
Need more info here please. What kind of computer is there any beep. Try to unplug your computer then while it's unplug hit the power button. Then plug Back in see if this helps
9/7/2014 9:02:46 AM • Acer Veriton... • Answered on Sep 07, 2014
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
8/2/2014 6:35:17 AM • Acer Veriton... • Answered on Aug 02, 2014
Microphone is mute and can't unchek now
Did you try plugging in a microphone before trying to unmute it?
7/31/2014 8:33:03 PM • Acer Veriton... • Answered on Jul 31, 2014
How can i reset my administration password if i
Use your windows disk and reset the password from there. 2. Boot into safe mode (using f8 at startup) and you will be logged into the built in admin account where you can change the other admin passwords. 3. Use the free Trinity Rescue Kit to recover the admin password.
5/6/2014 11:07:09 AM • Acer Veriton... • Answered on May 06, 2014
How to enter acer veriton m661 boot menu
On most PCs you need to press F8 continuosly wheen first starting your computer, If that does not work try you Del key
4/3/2014 3:33:50 AM • Acer Veriton... • Answered on Apr 03, 2014
Acer Veriton M420  PC Desktop Logo
8 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Veriton Acer
  • Veriton Acer
Most Popular Question
fitting external pci graphics card
  • Computers & Internet
