20 Most Recent
Arris High Speed DSL Modem Questions & Answers
I have had my motorola modem (MSTATEA) for a while
Hold the modem at different angles to a light and see if you can glean the missing parts of the code off of the sticker. Write it down if you get it, otherwise, if it was a wired switch on the back, that should still work. Good luck.
How to make my modem give out wifi?
check if your modem is cable in broadcasting wireless signal. if you can see wireless light in front of the modem then your modem is a router as well but if it does not have wireless light then you need a router hook up to it
When plugged in no llights
If there are no lights whatsoever illuminating when you have the modem plugged in to the electrical outlet, then this is going to indicate either a faulty power cord or a faulty modem. If you received this modem from your service provider, you may wish to contact them for assistance.
I can't connect to the
If your ethernet light is out, call your ISP, your internet service provider. There might be an outage in your area.Also try unplugging and plugging back in your router and modem and see if that helps.
I am having a problem
Does it feel hot to the touch? Is it dusty? Do you have it sitting where it can get air circulation around it? If it is getting air and isn't dusty the unit might be getting glitchy. They can do that before they go out sometimes. It may need to be replaced. However you may also have a problem with the connection itself on the other end (the provider's end). If you don't have a static ip address most ISP's will assign a different ip address if/when the modem is rebooted sometimes, but they can also keep the same ip address for a long time dispite rebooting. (when you unplug and start it again it is rebooting). You might want to check with your provider and see if they can change it to see if that helps. Sometimes it's their end that is glitchy...
I not able to log into my network using the same
Hi, try to remove your current connectivity setup then refresh new list for wifi connection, there you can have it pop up the access credentials again.If not access the wifi setting of your network to check the current password.
I have a Motorola 2210-02-1002 modem for a D-Link
You will need a power adapter with 12 Volts DC with .42 amps. The barrel will have to be negative and the tip is positive. It has these specs written on the back of the modem, just above the power port.
All lights on modem green,
When ALL the lights go out, even the power led, there is either a problem with the modem itself (a malfunction) or with the power supply. I'm assuming the move of your computer is unrelated to this issue. Since your modem is new and still under warranty, I's best to contact the store that sold you the modem right away.
How do you bridge a modem ? i have a problem
Bridging the modem actually disables the dhcp server on your modem...
If you bridge the modem, then the dhcp will get disabled which in turn disables NAT on your modem...
If you contact your ISP they will help you to bridge the modem... because bridging varies according to the ISP...
