20 Most Recent QDI Group QDI Advance 6T Motherboard Questions & Answers
2answers
Powers up, fans work, but nothing happens. Can not
I will assume that you have everything connected properly and are using the integrated video on the motherboard (not a separate video card installed in a slot). Usually the red light on the motherboard (mobo) is a power-on light, meaning that it is plugged in to a power socket.First try to clear your CMOS settings:Unplug the power cord and remove the CMOS battery for 15 minutes. If your mobo has a BIOS reset jumper, move it to the Clear position and back to normal. If you aren't sure what these things are, it will be in your manual that came with the mobo. Now re-connect everything and try again. Make sure that you are plugging the video cable into the proper socket and your monitor is working. If you can use a DVI cable on that board, try that connector. Make sure your monitor is working.>Visually check for failed capacitors; caps that have ruptured are increasingly common and can stop booting.>Your CPU may have failed; this is a typical situation then the chip fails. Everything works except there is no video on the monitor.For more detailed testing and information, go HERE.
10/10/2013 1:40:17 PM • QDI Group QDI... • Answered on Oct 10, 2013
Where can I find a
www .qdigrp .com
10/29/2010 5:03:33 AM • QDI Group QDI... • Answered on Oct 29, 2010
Qdi advance 6 gets to verifying pool data then
YES
4/15/2010 3:50:43 PM • QDI Group QDI... • Answered on Apr 15, 2010
QDI Group QDI Advance 6T Motherboard memory
make sure you are putting in the correct ram and make sure both are in good, may be registering only one, or maybe one is bad. try them one at a time in each different slot. should tell you if both chips/slots work
12/1/2009 7:55:27 PM • QDI Group QDI... • Answered on Dec 01, 2009
2answers
I installed a new operating
You also need to install the motherboard specific drivers to activate the various devices (sound etc). The motherboard manufacturer should have the current drivers available for download.
2/7/2009 8:57:43 AM • QDI Group QDI... • Answered on Feb 07, 2009
Can on board graphics be turned off on QDI Advance 6T Motherboard
To do this you need to enter your bios setup, under onboard devices you will find the onboard graphics. Click disable on it & your pci card will be your graphics. Hope this helps & please remember to rate my answer. Thanks.
12/29/2008 8:16:16 PM • QDI Group QDI... • Answered on Dec 29, 2008
Memory
It means the most your motherboard will support per slot is a 256 RAM. Also, on older systems, some RAMs are not compatible with others.
4/29/2008 6:25:17 PM • QDI Group QDI... • Answered on Apr 29, 2008
0answers
0answers
QDI AMD XP 3000+
Be the first to answer 4/16/2014 3:45:24 AM • QDI Group... • Posted on Apr 16, 2014Be the first to answer
0answers
0answers
0answers
Platinix 2 e
Be the first to answer 1/29/2014 9:13:44 AM • QDI Group... • Posted on Jan 29, 2014Be the first to answer
0answers
0answers
P6I845 PlatiniX-2
Be the first to answer 12/25/2013 3:20:00 AM • QDI Group... • Posted on Dec 25, 2013Be the first to answer
0answers
0answers
QDI Group QDI Advance 6T Motherboard Logo
11 questions posted
Top QDI Group Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • QDI Group Computers & Internet
Most Popular Question
powers up fans work but nothing
  • Computers & Internet
