20 Most Recent
LG WM2101HW 4.0 cu.ft. Washer Questions & Answers
Stopped spinning
Have the machine's rotor assembly and door latch checked out as these two are the most common causes for no spinning.
If the machine has been making a loud noise when it was still spinning, the tub bearing could be at fault.
I HAVE A LG WM2101HW
Had the same problem and it was exactly as rbozzell said. The main black drain hose in the bottom developed a small hole.
Motor no runnig
Is it the drum that is not moving? or actually the motor? Possibly it could be the belt from the motors rotor going around the drum , the one with the clothes inside it! that has fallen off or is broken?
Where is the hall sensor
A hall sensor is a magnetic pickup sensor that picks up magnetic pulses caused by a rotor that is bolted to the spinner shaft in back of unit. remove back access panel and motor rotor is facing you now. take bolt off of rotor and slide off. you should be able to see hall sensor under stator. remove bolts on stator to access hall sensor.
Remove soap drawer lg wm2101hw
the sponge is probably making it's way to the bottom of the machine as we speak. disconnect the power, and lean it back wards. the sponge should be on the ground there. otherwise pulling it out from the wall and removing the back panel should reveal it's location.
Lg wm2101hw code le
Press "end of cycle" for 3 seconds or till the flashing goes off . Plug off the wall. Code can be an indication of
several issues. The most common cause is over sudsing in the machine.
Overloading the wash with too much laundry may also cause the LE error
code. Lastly, a breakdown in the signal between the microprocessor and
the motor may cause that error code. This can occur if there is a loose
wire, see that all wires are tightened..........Click helped if helped.........
