20 Most Recent
Maytag MHWE300VW Washer Questions & Answers
My series 2000 maytag stops in the middle of wash/rinse cycle with l f on the front
The F1 code indicates that the main control board is not seeing a change in the water level.You need to check:The air dome hose(the clear plastic tube that goes down to the side of the tub) for clogs, kinks and tight fit at both ends.You need to check the wire harness, and connections at the motor RPS sensor (motor) and control board. If the airdome hose and attachment points are OK, check the harness and wires to the RPS / Motor assembly to be sure they are attached and that none are broken. Post back your results.
Sud error
Remove the lower kickplated and clear the filter out.
Mhwe300vw11 error code f 70
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.Be sure your unit is plugged into a 3 prong grounded outlet as well.F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.Thanks for using FixYa
The washer shuts off by
Hello Autumn,
The F21 error code means the pump has taken longer to drain the water than usually time it takes to drain. Here is what you check to see if something is in the drain pump filter restricting the water flow into the pump. I know i have the Whirrpool Duet washer pictured . Whirlpool makes that washer so other that the name "duet" everything is the same
The most prominent cause of your DUET washer not opening after the cycle is done and door remains locked is going to be a blockage in the drain pump. Here is what to check in the pictures below.
Start by unscrewing that just a little and use towel/tupperware tubs and catch the water that will come out. Once all the water is out remove completly and check for a blockage
