20 Most Recent FoodSaver Vacuum Food Sealer - V3840 Questions & Answers
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
FoodSaver Vacuum... | Answered on Nov 20, 2017
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
FoodSaver Vacuum... | Answered on Jan 25, 2016
Request from Foodsaver
FoodSaver... | Answered on Sep 12, 2019
Hi, if you go to YouTube, you will find a video showing you what to do,
I hope this helps
FoodSaver... | Answered on Apr 23, 2019
It is a heating element and heating elements fail. Contact the maker to see if they do spare parts. The only thing you can do is check the contacts on the end to make sure they haven't failed.
https://www.google.com/search?safe=off&ei=-AeQXLTWE-T45gKVh6CQCQ&q=foodsaver+vacuum+sealer+550+replacement+parts
FoodSaver... | Answered on Mar 18, 2019
NEEDS A NEW HEAT RIBBON WE DO NOT SELL THINGS OR MAKE THEM HERE
FoodSaver... | Answered on Feb 23, 2019
You can probably get one from the manufacturers web site.
FoodSaver... | Answered on Dec 22, 2018
Chances are that you foam gasket are not doing their job anymore. You can make a test by humidifying them with a paper towel. If it's works, you are due to replace them. They will usually last about 2 to 3 years depending on the use.
They are available through ebay or Amazon
FoodSaver... | Answered on Nov 26, 2018
The black foam seals are not doing their job anymore then. You may humidify them with a paper towel for a quick but it won't last. The vacuum sealer is expected to reach a certain level before automatically sealing it.
There is foam replacments available through ebay and amazon.
There's could be several elements to look into;
-is the vacuum still working or it stopped.?
.if it stopped without sealing chances are that the heating wire is broken.
if it's still try to vaccum, the seals probably not doing their and the expected vacuum levels are not reached.
To test that you can moister the foams seals with a paper towels.
If that worked, think about replacing the seals.
To deal with the sealing wire, you usually have to pull off a teflon tape to see it. I do believe that you can have a replacement for the wire. I personally never had to replace one.
bad heater element or debris on heat edges
FoodSaver... | Answered on Sep 03, 2018
FoodSaver Vacuum Food Sealer - V3840 Logo
6 questions posted
Top FoodSaver Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
lucboisseau5
Level 1 Expert
ray gallant
ray gallant
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • FoodSaver Kitchen Appliances - Others
Most Popular Question
v3840 heat strip doesnt get hot
  • Kitchen Appliances - Others
