20 Most Recent
Samsung LN46B640 LCD TV Questions & Answers
Vertical lines
You will most likely need to have the set diagnosed. Vertical lines can be the result of a defective t-con board, faulty lcd panel/t-con connections, or a faulty panel itself. Do the lines stay or do they come and go? Older Samsung sets are known for faulty LCD panels!
Red vertical lines
There are so many reasons for this fault.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window. Details of faults with illustration are given.
TV started with a few vertical yellow lines, now
It sounds that a loose contact to its flat wire connection that goes to panel from T'Con board. Re-seat it once and check. If you wish to get more, check this link. It has screen-shots to faulty LCD TVs, and you can compere to your TVs present appearance.
Pull up previous posts, either by type in the Brand name to
your set in its search box, or view it in
Mosaic / Timeslide / Flipcard option.
Select view option by the drop-down view box, at the top left or
the display window.
Vertical lines in picture
The machine is still under warranty from samsung so I would call 1-800-samsung to find the nearest service center. Problem could be caused by a bad main board, bad lvds cable or a defective t/con board or lcd panel.
TV picture is shaking up and down.
Try unplugging any devices near the TV one by one and see if that helps.
I had the same problem with my picture shaking on all HD channels and found that it was my land line phone interfering with the signal.
Hope that helps!
Vertical lines have appeared on my
if this tv is under warranty i would call samsung, there could be three board that could be going out on it one is the techon board, main board, but you also my need the ip board changed out to. i repair samsung all day long and i see this problem a bit.
