20 Most Recent JVC KW-NT1 Car GPS Receiver Questions & Answers
0answers
0answers
Last year I got this device and after 1 & half
Probably the gps antenna is not working due to rusty (water inside it). Check the antenna disassembling it. Third part antenna for the NT1 is not available due to proprietary connector so you must buy a (expensive) genuine new one from JVC. Sometimes it's possible repair the old one.
5/21/2011 9:36:14 AM • JVC KW-NT1 Car... • Answered on May 21, 2011
How do i access ALL the blue tooth and handsfree
You will be able to handle phone calls (answer, reject, hold, etc), and import up to 100 numbers from your phone's contacts database. First of all, you must pair them with each other. Go to 'Menu > Settings > Phone tab > Connect > [New Device]'. Your device is in paring mode now. Then, make your phone's bluetooth application search for new devices. After a little while, KW-NT1 should appear on the phone' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, you should see 'Connected' on your Car GPS receiver. Press 'OK' to confirm the operation. They are paired now. You will be able pair other 4 phones with this car GPS receiver (but connect only one of them at a given time). Now to import some of your phone's contacts database, from any screen, press DISP. When the AV bar appears, press the bluetooth icon, then 'Call Menu > Phone Book > Add', and see your phone screen for the selection of the number you want to import. For each additional number, repear from the 'Add' button. When you are done, press 'Finish'.
You will be able to make calls by dialling a new number, by going to 'DISP > bluetooth icon'. To dial from the call history or the stored phone book entries, press 'Call Menu'.
These are the basic functions. For additional resources on this car GPS receiver's bluetooth implementation, please, take a look at its user guide, from pages #77 to #84. You can download it from this location.
Please, let me know if I can assist you any further.
Regards, Carlos
1/6/2011 5:30:33 PM • JVC KW-NT1 Car... • Answered on Jan 06, 2011
0answers
JVC KW-NT1 GPS not working in UK
Have you tried re-flashing the unit with the latest EU firmware update available from the JVC website? http://www.jvc-victor.co.jp/english/car/support/navi/nt1/eu/index.html Should overide the current firmware then allow you to use UK maps. If it doesn't work you can always reflash it with the USA update.
3/29/2010 9:34:57 PM • JVC KW-NT1 Car... • Answered on Mar 29, 2010
WILL A JVC KW-NT1 FIT IN MY 04 CHEV. MONTE CARLO?
If the vehicle can take double-din radio, it can be mounted.
You need to buy harness adapters.
1/19/2010 6:55:09 PM • JVC KW-NT1 Car... • Answered on Jan 19, 2010
3answers
I need a wiring diagram
For all those in need - here's a schematic I drew up. It's got a fuse, and filtering (inductor / capacitor) - but the connector is a 4-pin MOLEX like you see for +12v on an old P4 board. Pin 2 - (GND) Pin 3 - +12v (out of this schematic box) - could try it with just a fuse no filter, but JVC link is VERY unreliable when there's noise Got problems with your KS-BTA200 adapter anyone? Here's the problem - inside the adapter, they wanted to save 1 screw, so they grounded the shield to the holding bracket (which "touches" PCB ground sort of). Buy a 20c M4 sheet metal screw, 5c star washer you'll see a spot for shield ground on the PCB and housing inside the KS-BTA200. Ground that sucker right - my old one that went out works SOLID now :) (pass it on) ks-sra100-(power_cord)-gvux3kiokajvd5y1ar3i0axc-6-3.jpgks-sra100-(power_cord)-gvux3kiokajvd5y1ar3i0axc-6-2_0.pngHopefully you can see the schematic, website is bogging down
8/30/2020 8:15:15 AM • JVC GPS • Answered on Aug 30, 2020
JVC GPS navigation system model number k wnt1 comes on show screen that's all
it might need updated . load the driver an plug it into a pc
5/10/2015 8:12:23 AM • JVC GPS • Answered on May 10, 2015
0answers
0answers
Jvc kw xc838
Be the first to answer 1/19/2014 3:05:09 PM • JVC GPS • Posted on Jan 19, 2014Be the first to answer
0answers
Jvc kd r526
Be the first to answer 10/31/2013 5:31:08 AM • JVC GPS • Posted on Oct 31, 2013Be the first to answer
Trying to update a kv-px9sn gps, i have the new
why dont you try to save it as disk image(.iso) and load it from the computer , you can do this with several burning sofwares let me know if U have any questions about disc image(.iso) . [email protected]
1/31/2011 5:41:57 AM • JVC GPS • Answered on Jan 31, 2011
0answers
I have the jvc kv-px98
Be the first to answer 10/19/2008 2:48:26 PM • JVC GPS • Posted on Oct 19, 2008Be the first to answer
I have deleted the English keyboard from my Nuvi
Connect your unit up to the PC and run Garmin's webupdater program. It will scan your unit and tell you what updates are available and if you deleted a file, it will allow you to re-download it. You can find the program here: http://www8.garmin.com/support/collection.jsp?product=999-99999-27
4/21/2024 6:01:48 PM • GPS • Answered 2 days ago
2answers
Bosch acs 650 calibration password
password is 227
4/20/2024 9:32:59 AM • GPS • Answered on Apr 20, 2024
JVC KW-NT1 Car GPS Receiver Logo
15 questions posted
Top JVC GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a JVC GPS Expert? Answer questions, earn points and help others
View Most Popular
JVC GPS
  • JVC GPS
Most Popular Question
last year got device after 1 amp half
  • GPS
